Removing rollers makita 2030
Forum topic by Oldnintheway posted 03-24-2019 01:32 AM 3522 views 1 time favorited 12 replies Add to Favorites Watch
View Oldnintheway's profile
Oldnintheway
10 posts in 915 days
03-24-2019 01:32 AM
Topic tags/keywords: planer jointer
Hi all,
I just signed up after finding this forum searching google for help. I recently purchased a Makita 2030 jointer/planer. I was perusing craigslist for a jointer and came across this. Had never heard of it but everyone seems to rave about them and a planer is always good to have so I bought it. It’s in pretty good shape from what I can tell so far. But as usual the rollers need to be re-coated. I intend to send them to Western Roller when I get then removed. I’ve read through quite a few thread here and elsewhere but haven’t found any instructions on the removal. I’m not real mechanically inclined but if it’s at all intuitive I can usually get it done. I’d really like to know the process before I tear into it to hopefully avoid ruining anything along the way. I have had the side cover off that exposes the gears. And I’ve located the phillips head screws that everyone has trouble with. I couldn’t budge them either. I have read some tips like using an impact wrench and various lubricants. If anyone has this knowledge and would care to help it would be much appreciated! Pictures/vids are always the best but I haven’t found any. I did download the manual but it didn’t address this issue that I could find.
Thanks much! Jim
12 replies so far
Oldnintheway
#1 posted 03-24-2019 01:52 AM
Oops. Please delete.
Oldnintheway
#2 posted 03-24-2019 02:56 AM
This is what I attempted with the last post but failed. :)
View MrUnix's profile
MrUnix
8751 posts in 3415 days
#3 posted 03-24-2019 05:03 AM
You need to remove the drive chain and gears from the end of the rollers first. Remove the circlips holding the gears on, then pull up on the tension roller and the chain and gears should come right off. I found it easier to go ahead and remove the rest of the gears and backing plate as well, as it gives you extra access to the rollers – but it is not required.
Once you have the gears (and their woodruff keys) off, you just need to remove the 8 screws (4 per roller, 2 per side) that hold the bearing retainers in place. The screws can be a PITA as they are JIS, not Phillips. Lacking a good JIS screwdriver or bit, I found it easiest to use a Phillips bit in a 1/4” ratchet, which gives much more torque than a regular screwdriver:
Once you get them out, replace with socket head screws to make future removal easier. If you have buggered up a screw beyond hope – grab it with a pair of vice-grips to get it going… once it turns just a hair, it’s super easy to remove the rest of the way (sometimes just with your fingers).
Here are some notes I made regarding the actual roller removal:
The rollers are supported in what Makita calls a “plane bearing” which is just metal sleeve (bushing). They are spring loaded, so be careful when removing. The easiest way I found is to first loosen the bearing support on the gear side of the roller first. Do not remove it yet, just back the screws out a quarter inch or so. Next, remove the bearing support on the opposite side of the roller. This will let that side drop down enough to slide the roller out of the bearing on the gear side. Once the roller is removed, the other bearing support, bearing and spring can be taken out. Do this for both rollers. Examine the old bearings to make sure they are not worn or damaged and replace if needed.
View WSeattle's profile
WSeattle
3 posts in 915 days
#4 posted 03-24-2019 05:29 AM
Gents, I have the exact same challenge ahead and am very grateful for this excellent description. Thanks
Oldnintheway
#5 posted 03-24-2019 06:50 AM
WOW! Many thanks for that detailed description Brad! More than I could have hoped for. It will be a few day before i can get to it. I’ve been down with a herniated disc the past two weeks and just getting back on my feet .I’ll let you know how I make out. Might have a question or two. :)
Thanks again! Jim
Oldnintheway
#6 posted 06-08-2019 01:22 AM
Well my back has finally given me permission to proceed. I removed the rollers and sent them off to Western Roller. It was a smooth transaction, final cost including shipping both ways was a bit over $200.00. $172.60 for the resurfacing alone. Getting the rollers back where they go would have been easier with another hand, but I accomplished it by myself with some frustration. It’s just tricky getting the spring/bearing in place, holding the roller up and starting a screw. The reverse of what Brad suggested worked best for me. The unit now works like a charm! Next I need to get the blades sharpened and buy a back-up set. Thanks much Brad! Very much appreciated!!
Jim
View snacked's profile
snacked
1 post in 120 days
#7 posted 05-27-2021 04:13 AM
I’ve got this same job coming up soon. Glad i found this. Do any of you happen to have experience replacing the drive belt?
Thanks!
John
MrUnix
#8 posted 05-27-2021 04:41 AM
Yes. I described it around here somewhere but can’t find it… basically, you just need to split the drive pulley on the cutterheads. They are two parts, each held in place with set screws. You only need to loosen one side and pull it away from the other side – just enough to get the belt through.
View Spz's profile
Spz
3 posts in 12 days
#9 posted 09-11-2021 04:53 PM
I have the makita 2030 n… cleaned it up yesterday with rust remover and gummed up some the table etc. I cleaned off as best I could, was using today, it was skipping so I adjusted the chain and worked fine but now the wood is not being pulled through. Help?
View Spz's profile
Spz
3 posts in 12 days
#10 posted 09-11-2021 05:07 PM
Brad in Fl… are you available?
MrUnix
#11 posted 09-15-2021 05:26 AM
- Spz
The 2030 is not the same as the 2030N, so I can’t really help with specifics… but if you gummed up the table and now it’s sticking – then I would think that is the root of the problem. Clean it up good with some solvent (ie: Mineral Spirits) and a scotch-brite pad and after cleaning, give it a good coat or three of paste wax. Also make sure the drive rollers are clean.
How did you ‘adjust the chain’? There is no way to adjust it on the 2030, and I thought the chain path was basically the same on the 2030N.
View Spz's profile
Spz
3 posts in 12 days
#12 posted 09-15-2021 04:13 PM
Hi again thanks for your response. You are correct the chain is not adjustable that was probably the wrong term I took the chain off, And remove the roller sprocket to find that the bearing holding the roller was almost completely worn out I have since ordered new bearing blocks to insert the roller into I think that should Take care of my roller issues and feed right finally I am still wondering if there is a replacement motor out there for this machine? Thanks for all your help
