Delta 36-725 Fence rail extension???
Forum topic by jlozan2 posted 03-22-2019 06:24 PM 301 views 0 times favorited 16 replies Add to Favorites Watch
View jlozan2's profile
jlozan2
35 posts in 171 days
03-22-2019 06:24 PM
Topic tags/keywords: delta 36-725 table saw fence rail
Hey guys,
I have the Delta 36-725 model and love it! I just hate that I only can cut up to 30” on the right side. I do a lot of cabinet work and not having the ability to cut 34-35” is rather annoying.
Does Delta make a 36” rail for the saw?
Or would anyone recommend a fence and rail system that can cut up to 36” on the right side of the blade?
16 replies so far
View WhyMe's profile
WhyMe
1140 posts in 1891 days
#1 posted 03-22-2019 06:36 PM
Look for “Delta 36-T50 T3 Fence”. But it still shows 30” max rip to the right. ???? That’s got to be wrong on the HD site because other places show 50” max right rip which is what it should be.
https://www.homedepot.com/p/Delta-Power-Equipment-50-in-T-Square-Fence-and-Rail-System-36-T50T3/205803794
jlozan2
#2 posted 03-22-2019 06:44 PM
I saw that one too but that thing is huge lol it really wouldnt fit in my shop. I just need it to be 36” not 50”.
- WhyMe
View Steve's profile
Steve
1181 posts in 913 days
#3 posted 03-22-2019 07:00 PM
Can you just move the rails to the right 15-20”?
jlozan2
#4 posted 03-22-2019 07:03 PM
I guess i could but the holes on rails are pre-drilled to be bolted on to the top of the table saw.
- Steve
View knotscott's profile
knotscott
8267 posts in 3706 days
#5 posted 03-22-2019 07:05 PM
On some saws its possible to slide the rails over by one bolt hole, so you don’t even have to drill. Not sure if it’ll work with this saw but is worth some investigation.
knotscott
#6 posted 03-22-2019 07:06 PM
double post, triple post… who knows? Sorry!
knotscott
#7 posted 03-22-2019 07:07 PM
On some saws its possible to slide the rail over by one bolt hole, so you don t even have to drill. Leave the bracket where it is and just move the fence rail over by a bolt hole. It’ll leave you with one less bolt in the fence. Not sure if it ll work with this saw but is worth some investigation.
- knotscott
View pottz's profile (online now)
pottz
4740 posts in 1314 days
#8 posted 03-22-2019 07:10 PM
- Steve
- jlozan2
pre drilled but what about (re-drilled) ? hey where theirs a will theirs a way!
jlozan2
#9 posted 03-22-2019 07:38 PM
I’m afraid there will alignment issues if i do that plus i’d have to buy new tape. I’d rather just buy something thats plug-and-play.
- Steve
- jlozan2
- pottz
knotscott
#10 posted 03-22-2019 07:45 PM
I m afraid there will alignment issues if i do that plus i d have to buy new tape. I d rather just buy something thats plug-and-play….
- jlozan2
The Vega Pro 40 is a nice fence with an excellent micro adjuster, and is fairly easy to install….~ $331 shipped.
View FirehouseWoodworking's profile
731 posts in 3603 days
#11 posted 03-23-2019 04:37 AM
If you need to cut 36” from a sheet of plywood, what about setting the fence a 12” (minus the thickness of the blade) and cut off the “waste side” of the plywood?
Cheers!
-- Dave; Lansing, Kansas
Steve
#12 posted 03-23-2019 11:47 AM
Drilling new holes and a new stick on tape would cost maybe $10 and 30 mins
jlozan2
#13 posted 03-25-2019 02:35 PM
I’ve tried that before but it never comes out true.
Cheers!
- FirehouseWoodworking
View Lazyman's profile
Lazyman
3226 posts in 1717 days
#14 posted 03-25-2019 02:50 PM
I would think that any kits that you buy are going to require you to drill holes to match the saw or worse into the saw itself and you will probably have to apply your own tape so that it aligns perfectly to the blade position. The tape on mine was not accurate past about 12” so I bought a new one (but just haven’t applied it yet).
jlozan2
#15 posted 03-25-2019 02:53 PM
Yea I think i’m just going to make a big panel sled. I really don’t want to drill into the saw since I plan on reselling it to get something better later on. I want to keep everything original.
I would think that any kits that you buy are going to require you to drill holes to match the saw or worse into the saw itself and you will probably have to apply your own tape so that it aligns perfectly to the blade position. The tape on mine was not accurate past about 12” so I bought a new one (but just haven t applied it yet).
- Lazyman
