How do I remove bench vise faceplate from screw?
Forum topic by lfrager posted 03-22-2019 01:04 PM 305 views 0 times favorited 4 replies Add to Favorites Watch
View lfrager's profile
lfrager
2 posts in 214 days
03-22-2019 01:04 PM
Topic tags/keywords: vise woodvise workbench workbench vise bench vise
I have this bench vise made by woodriver from woodcraft. I made the mistake of not keeping track of where the front of the mounting bracket was and drilled the holes in backwards. Essentially, I think that I can most easily fix the mistake if I can just mount the faceplate on backwards. The problem is that I can’t figure out how to remove the faceplate from the main screw. Here is the picture to help. Any suggestions are appreciated!
View SMP's profile
SMP
1401 posts in 418 days
#1 posted 03-22-2019 02:04 PM
See the smaller hole in the base of the handle? I think around 1/4” There is a roll pin in there that needs to be popped out, you can use a hammer and punch if you have one or even a smaller screwdriver, broken drill bit, etc. To be honest, some of those cheaper vise handles can sheer off that roll pin if you really crank something down, when you replace the pin you can look for a solid pin or put a screw into the center of the pin aftter installing.
View HokieKen's profile
HokieKen
10963 posts in 1651 days
#2 posted 03-22-2019 03:30 PM
Yep^
-- Kenny, SW VA, Go Hokies!!!
lfrager
2 posts in 214 days
#3 posted 03-24-2019 01:11 AM
That worked easily. Thank you!
View MikeDilday's profile
MikeDilday
259 posts in 972 days
#4 posted 03-24-2019 01:21 AM
Just glue dowels in the holes and do it over.
-- Michael Dilday, Suffolk, Va.
