Filling cracks
Forum topic by Mike posted 03-21-2019 04:06 AM 197 views 0 times favorited 4 replies Add to Favorites Watch
View Mike's profile
Mike
70 posts in 2227 days
03-21-2019 04:06 AM
Hello fellow woodworkers. I have a project that I’m going to attempt which will require filling some pretty good size cracks. I know the current rage is to fill them with epoxy, which I have done. My question is with the high cost of epoxy has anyone tried to fill cracks with a mixture of sawdust and wood glue? My thought is to fill the deep cracks most of the way then finish the fill after it dries with epoxy. Anyone try that method?
View Cold_Pizza's profile
Cold_Pizza
14 posts in 84 days
#1 posted 03-21-2019 04:24 AM
I’ve done this with titebond 2 with no issues. I’m sure it goes without saying but make sure the glues fully dry first. Can’t speak for any other brand
View LesB's profile
LesB
2053 posts in 3775 days
#2 posted 03-21-2019 07:11 PM
I have had good luck using CA glue and saw dust.
I found that I could pack the crack with fine sawdust as tight as possible. Then quickly soak it with the thin CA glue, immediately followed with medium or thick CA glue. The thin glue acts as a wicking agent to pull the thicker glue into the sawdust.
-- Les B, Oregon
View OSU55's profile
OSU55
2209 posts in 2321 days
#3 posted 03-21-2019 07:59 PM
Sawdust and woodglue will work but you might not like what it looks like. Dont know what you plan to do, ie sand/finish in some way etc. Do a test if possible to see if you like it.
View BlueRidgeDog's profile
BlueRidgeDog
479 posts in 111 days
#4 posted 03-21-2019 08:16 PM
I use microballoons to extend the fill capacity of epoxy, using it on the first and or second pour, so the final is pure epoxy.
