Shadow box, attaching contents
Forum topic by Charlie H. posted 03-20-2019 11:41 PM 246 views 0 times favorited 9 replies Add to Favorites Watch
View Charlie H.'s profile
Charlie H.
347 posts in 983 days
03-20-2019 11:41 PM
Hello,
I am building a wall hanging shadow box or maybe just a frame to display a brace & bit set that belonged to my uncle.
This will be gifted to my aunt or to one of my female cousins.
The display box / frame is all milled lumber, while not exactly what I would call fine woodworking it’s not rustic looking either.
My leading candidate to attach the brace and bits to the back panel is some thin steel wire that I would paint black.
The back panel is wood. Looking for alternate recommendations that will be unobtrusive.
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
9 replies so far
View JohnMcClure's profile
JohnMcClure
599 posts in 973 days
#1 posted 03-21-2019 12:06 AM
Thin black wire is good. I used thread in s similar application.
-- I'd rather be a hammer than a nail
View duckmilk's profile
duckmilk
3435 posts in 1657 days
#2 posted 03-21-2019 12:45 AM
I think thin wire, black or plain, if attached to the brace in unobtrusive places would be virtually unnoticeable. Not sure how the bits should be hung. Good luck!
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
View SMP's profile
SMP
629 posts in 238 days
#3 posted 03-21-2019 05:46 AM
I would use rebar tie wire. Its already black. Most home centers would have it in concrete/rebar section.
View HackFabrication's profile
HackFabrication
106 posts in 44 days
#4 posted 03-21-2019 08:07 AM
You might also consider using the brace & bits to bore some holes into a matching/contrasting piece of wood to hold the bits and brace to the shadow box. Cut the piece down the center to get some semi-circular brackets to mount the brace/bits to. I fabricate up some nice (but semi-rustic) steel straps to brad nail into the brackets to help support the brace/bits.
Using the tool in the construction of the display, will add some more character to it for the recipient.
-- "In the end, it's all Hack..."
View HokieKen's profile
HokieKen
8959 posts in 1471 days
#5 posted 03-21-2019 01:13 PM
You could also imbed some powerful rare earth magnets in the back panel. Just an other option to consider :-)
-- Kenny, SW VA, Go Hokies!!!
Charlie H.
#6 posted 03-21-2019 11:32 PM
Thanks to all for the ideas, they are appreciated.
View Madmark2's profile
Madmark2
447 posts in 921 days
#7 posted 03-22-2019 01:18 AM
Put in a sheet of felt over the back before attaching the brace & bit.
For medal boxes put a sheet of 1/2” Styrofoam under the felt. Blue for navy green for army and red for item show cases.
Attach felt with spray adhesive in all cases. Thin cork (1/16”) works too.
M
Charlie H.
#8 posted 03-26-2019 08:02 PM
I went with some steel wire.
View SMP's profile
SMP
#9 posted 03-26-2019 08:37 PM
very cool! THanks for sharing
