Need help with drawer sizes for Grass Dynapro 3d under mount drawer slides
Forum topic by SweetTea posted 03-20-2019 02:24 PM 375 views 0 times favorited 5 replies Add to Favorites Watch
View SweetTea's profile
SweetTea
390 posts in 988 days
03-20-2019 02:24 PM
So I am trying out undermounts for the first time. Decided to go with the Grass Dynapro 3d slides. These are for an inset application and I have the appropriate right and left locking devices for both the front and back. I also have the rear brackets for the slides themselves, and the jig for the holes in the drawer for the locking devices. So I think that I am all set, but having never used undermount slides before, I am unsure how wide and deep to make the drawer boxes? I am using 3/4” pine for the drawer boxes and 1/2” pine ply for the drawer bottoms.
What width should the drawers be relative to the opening?
5 replies so far
View DS's profile
DS
3112 posts in 2749 days
#1 posted 03-20-2019 05:01 PM
First off, for 3/4” drawer sides you need to be sure to use the Dynapro 19 guides. Dynapro 16’s are meant for 5/8”
Maybe you already verified this – I’m just trying to be thorough with my reply.
Secondly, undermount guides are calculated from the INSIDE of the box, since that is the point of contact with the guide. For the Dynapro 19 it is 31/32” from the inside of the drawer to the side of the opening on each side.
Figuring a 3/4” side thickness, your overall box width would be the opening minus 7/16”.
Here is the relevant page in the Dynapro catalog.
Hope that helps.
SweetTea
#2 posted 03-23-2019 11:34 AM
First off, for 3/4” drawer sides you need to be sure to use the Dynapro 19 guides. Dynapro 16 s are meant for 5/8”
Maybe you already verified this – I m just trying to be thorough with my reply.
Hope that helps.
- DS
I checked the box and I have the Dynapro 16’s so I will plane down my drawer sides (tail boards) to 5/8”. What would the calculation be for 5/8” sides?
SweetTea
#3 posted 03-23-2019 11:12 PM
Can anyone tell me how to figure this for 1/2” or 5/8” drawer stock?
SweetTea
#4 posted 03-24-2019 02:34 PM
Ok I figured it out. For 1/2” sides, you subtract 5/8” from the opening. Now does any one know if the 21” Grass Dynapro 16’s take exactly a 21” drawer? Or should I make the drawer a little less?
View DS's profile
DS
#5 posted 03-25-2019 03:48 PM
Sorry, I was off the board for a while.
Deduct 3/8” overall (3/16” per side) for clearance using the Dynapro 16’s and 5/8” Sides.
Deduct 5/8” overall for 1/2” sides using Dynapro 16’s.
Relevant page in the catalog here
Make the drawer exactly 21” deep overall.
This is a good drawer slide. You should like them once you get it dialed in.
