Drawer that opens (pushes through) on both sides?
Forum topic by J_J posted 03-20-2019 01:02 AM 1633 views 0 times favorited 26 replies Add to Favorites Watch
View J_J's profile
J_J
10 posts in 43 days
03-20-2019 01:02 AM
I’m currently in the middle of designing a bed frame that has storage underneath. The storage system I’m trying to develop are two large drawers that have the ability to be pulled out on both sides of the bed with out restrictions. I have been trying to find drawer slides that allow for this movement but I have had no luck. I have also been trying to see if this type of drawer has a name, all I have been able to find is a “Peninsula Drawer” but that was a one time find.
here is a quick illustration to help visualize it.
Any recos are welcomed.
26 replies so far
View wuddoc's profile
wuddoc
342 posts in 4050 days
#1 posted 03-20-2019 01:48 AM
What about a cleat attached to the carcass on either side of the drawer with a corresponding dado or 1/2 dovetail on each draw side.
-- Wuddoc
View LeeRoyMan's profile
LeeRoyMan
45 posts in 59 days
#2 posted 03-20-2019 02:26 AM
View John Smith's profile
John Smith
1759 posts in 495 days
#3 posted 03-20-2019 02:29 AM
put some thought into conveyor roller balls. then you could build big
hefty drawers that would slide in and out with little effort.
available from several online sources.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
View SMP's profile
SMP
622 posts in 238 days
#4 posted 03-20-2019 02:43 AM
I did something similar with the rollers above, salvaged from a busted telescoping outfeed table, screwed to the bottom of the drawer. I had some issues getting it to stay in place in the middle and finally settled on some ball catches that worked:
https://www.homedepot.com/p/Prime-Line-1-2-in-Satin-Nickel-Solid-Brass-Surface-Mount-Ball-Catch-N-7288/100567700
View CaptainKlutz's profile
CaptainKlutz
1109 posts in 1827 days
#5 posted 03-20-2019 05:32 AM
+1 Accuride
US PN is 0363 series
https://www.accuride.com/c0363-light-duty-two-way-travel-slide
View WoodenDreams's profile
WoodenDreams
546 posts in 243 days
#6 posted 03-20-2019 08:11 AM
I like John Smith idea on using roller balls. Menards, Lowes, Home Depot and Harbor Freight sells them. Mount them to the bottom of drawer or mount several in a row to the frame. They do roll very easy. I’ve mounted them on the bottom of milk crates and storage boxes for wood scraps. they roll out from under my work bench with little effort. Rockler has them https://www.rockler.com/accuride-9301e-heavy-duty-600-lb-full-extension-drawer-slides as grizzly has them https://www.grizzly.com/products/Fulterer-28-Drawer-Slide-100-lb-Capacity/T26450 The ones that pull out all the way with no droop are pricy. The drawer slides we have under our bed will pull out 3’ on not even droop.
View bmerrill's profile
bmerrill
49 posts in 406 days
#7 posted 03-20-2019 01:11 PM
Paymasters drawer.
-- "Do. Or do not. There is no try". Yoda
View BlueRidgeDog's profile
BlueRidgeDog
479 posts in 112 days
#8 posted 03-20-2019 01:26 PM
What functionality is gained by one drawer vs two other than the 1.5” of space used by two backs and a small gap? There is nothing wrong with wanting it a certain way, but I am curious as to the advantages. The only thing I can think of is being able to get at contents that are on the far side while standing on the near side.
View Lazyman's profile
Lazyman
3230 posts in 1720 days
#9 posted 03-20-2019 01:36 PM
I am with Blue on this. I think it would be simpler to have 2 smaller drawers. Unless you plan or need to pull the entire drawer out one side for some reason, in which case you would need a really long slide depending upon what size bed this is for, I don’t see any advantage to having a single drawer that can be pulled out on both sides compared to 2 drawers.
View SMP's profile
SMP
#10 posted 03-20-2019 02:28 PM
- BlueRidgeDog
They are great for storing long items. Wrapping paper rolls, curtain rods, seasonal decorations, etc.
View AlaskaGuy's profile
AlaskaGuy
5196 posts in 2641 days
#11 posted 03-20-2019 02:42 PM
I think J_J left out a critical piece of information. What sizes are these drawers? A light duty accuride isn’t going to work if the drawer is 5 feet deep. My bed is 5’ wide.
BlueRidgeDog
#12 posted 03-20-2019 03:00 PM
- SMP
Thanks. Since I have found myself a bachelor and my kids have moved out, I have forgotten about such things as I throw out unused curtain rods, buy wrapping paper when needed and don’t decorate based on the season. I do remember those days though! Man the pain it brings back! I remember bringing out the decor for Easter, Halloween, Christmas….
View Snipes's profile
Snipes
394 posts in 2577 days
#13 posted 03-20-2019 03:53 PM
I would bet you could use the older style Blum. The steel ones that taper back last 3”. You could put one on each side, which would hold it in place sort of, you would have to cut backs off, and front and back of center one. Just thinking out loud
-- if it is to be it is up to me
View SMP's profile
SMP
#14 posted 03-20-2019 04:45 PM
- SMP
Thanks. Since I have found myself a bachelor and my kids have moved out, I have forgotten about such things as I throw out unused curtain rods, buy wrapping paper when needed and don t decorate based on the season. I do remember those days though! Man the pain it brings back! I remember bringing out the decor for Easter, Halloween, Christmas….
- BlueRidgeDog
Yeah I personally wouldn’t care, but its all my wife’s stuff. Now in the garage, I have no place for my 3’ breaker bar. I always wanted to get the middle tool chest for my set, but never wanted to spend the extra money for the full width drawer.
View J_J's profile
J_J
10 posts in 43 days
#15 posted 03-20-2019 04:59 PM
Hot damn, thank you for all of your replies.
I do like the roller ball idea that John Smith provided, seems very minimalistic which is always good.
I am with Blue on this. I think it would be simpler to have 2 smaller drawers. Unless you plan or need to pull the entire drawer out one side for some reason, in which case you would need a really long slide depending upon what size bed this is for, I don t see any advantage to having a single drawer that can be pulled out on both sides compared to 2 drawers.
- Lazyman
- Lazyman
The reason for these two long drawers is so I don’t have to build four drawers and mount four drawers. These are two long drawers that are accessible on both sides of the bed and it gives room for longer items if need be. A more simplistic approach to over complicating a build with more. Just my take on it.
I think J_J left out a critical piece of information. What sizes are these drawers? A light duty accuride isn t going to work if the drawer is 5 feet deep. My bed is 5 wide.
- AlaskaGuy
Yes I did not mention the size of the drawer which would be between 5 & 5.75ft in depth.
