Anyone try the new Grizzly G0889Z?
Forum topic by Eric_J posted 03-19-2019 06:54 PM 5230 views 0 times favorited 12 replies Add to Favorites Watch
View Eric_J's profile
Eric_J
3 posts in 612 days
03-19-2019 06:54 PM
Hello everyone,
I’m a frequent viewer but new poster/member to the site. My old Ryobi 10” thickness planer is crapping out on me so now its time to buy a real machine :) .
I’ve been thinking of the Dewalt 735 but then I saw that Grizzly just put out a 13” planer that includes a spiral head cutter (G0889Z). Has anyone tried this model yet? Seems like a nice unit for the price considering it comes with a spiral head cutter already.
thoughts?
thanks,
Eric
12 replies so far
View BalsaWood's profile
BalsaWood
179 posts in 1965 days
#1 posted 03-19-2019 11:40 PM
Wow it comes with a spiral cutterhead. Not sure how good the planer is but seems like a really good price.
View Ripper70's profile
Ripper70
1378 posts in 1715 days
#2 posted 03-19-2019 11:57 PM
Doesn’t look like you could get one if you wanted to. It seems they may be on back order. HD is having a sale today on the DeWalt. Today’s special buy. You’ll have to act quickly.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View Scap's profile
Scap
123 posts in 734 days
#3 posted 03-20-2019 12:05 AM
Doesn t look like you could get one if you wanted to. It seems they may be on back order. HD is having a sale today on the DeWalt. Today s special buy. You ll have to act quickly.
- Ripper70
Love the “limit 5”...
It is a really good price for anyone considering taking the plunge.
View HackFabrication's profile
HackFabrication
168 posts in 518 days
#4 posted 03-20-2019 01:19 PM
I don’t know about the Grizzly, but I own the DeWalt 735 and the DeWalt mobile base. It does a good job, but be forewarned, it has an internal chip blower that will blast debris everywhere unless a good containment system is used. I just read the specs on the Grizzly, and the depth adjustment has a locking mechanism. Planers with this sort of adjustment must be locked or they will ‘creep’, whereas the Dewalt uses a different system, and doesn’t need a locking mechanism to prevent creep.
I Hack Fab’d a simple trashcan lid separator and bag arrangement:
I see no need at present to eliminate the bag and attach the vac or DC to the can.
-- "In the end, it's all Hack..."
Eric_J
3 posts in 612 days
#5 posted 03-20-2019 04:14 PM
@Ripper70 thanks for pointing out the special buy, unfortunately I missed this lastnight and by the time i checked this morning, it was gone :/
@HackFabrication good to know about the blower and nice hack! I might have to try replicating your hack if I end up buying the DW735
I’m torn between buying the Dewalt DW735 and the Grizzly G0889Z. Even though the G0889Z is on back order, the price seems attractive considering it comes with a spiral head cutter. The DW735 is a workhorse but adding a spiralhead cutter would be another $500 (almost as much as the planer itself).
I question if I need a powerful planer or can get by with a simple benchtop one. For me this is just a hobby, I havent even tried to make money from it yet so the $ investment is a bit of a blackhole. However, I do seem to use rough lumber often and seem to be drawn to rough lumber due to price, etc.
At this point, anything is going to be better than my cheap 10” ryobi planer that I bought at an auction for $60 :)
HackFabrication
#6 posted 03-20-2019 06:48 PM
Based on what you posted, I’d just get the DeWalt. Use it for a year or two, then decide if you want to get a Big Boy 20” or bigger planer. Re-selling it used will help offset a tiny bit of the bigger machine. Or upgrade it to a Shelix head at that time.
Replacement DeWalt blades aren’t too expensive. And they can be ‘flipped’ because they are sharpened on both sides. Removal/install is very simple.
View JRsgarage's profile
JRsgarage
383 posts in 1316 days
#7 posted 03-20-2019 07:03 PM
Eric_J
3 posts in 612 days
#8 posted 03-21-2019 05:58 PM
@HackFabrication you make a good point. I think you’re right and I will just start out with the Dewalt. Thanks.
@JRsgarage thanks for pointing out that sale on Ebay. I just placed my order :)
View Mainiac Matt 's profile
Mainiac Matt
9599 posts in 3135 days
#9 posted 03-21-2019 06:31 PM
My problem with the G0889Z is that it appears to be just an older style ‘lunch box’ upgraded with a spiral head.
I can’t see how this configuration will avoid the classic lunch box planer problem, which is snipe.
The newer style lunch box planers have the ability to clamp the cutter head assembly to the four posts, which (mostly) prevents the cutter head from tilting as a board enters/exits the planer and greatly (but not completely) reduces snipe.
I tried all of the hacks know to man for dealing with the snipe on my old Delta lunch box, and some of them helped, but without clampling/locking the head to the posts, you’re going to get snipe.
I wouldn’t want to be the Gini-pig for this new;/old Grizzly planer… as it might wind up just being an old lunch box pig with lipstick on it.
-- Matt -- I yam what I yam and that's all what I yam
View Jeremymcon's profile
Jeremymcon
414 posts in 1486 days
#10 posted 04-04-2020 03:59 PM
Don’t get the grizzly with the spiral head. I had two of them, both defective. The cutter head machining just isn’t ready for prime time yet. It’s a true spiral head, with the cutters positioned at a shearing angle. But the machining is really poor, so you end up with scallops or lines at every cutter. It’d take a hell of a lot sanding to get them out, probably more than if you just let a straight knife tear out a little.
View Madmark2's profile
Madmark2
1464 posts in 1395 days
#11 posted 04-04-2020 04:46 PM
I have a G0889 (not the Z) and it is a new design, not a rework of an old model (G0505). Improvements include:
  • Cutter head lock for reduced snipe
  • Actual cut depth indicator
  • Clear exhaust port
  • Catch bag – no DC needed
  • Preset depth stop
  • 1/8” minimum thickness
  • Three blades vs two in the cosmetically similar G0505
The Z model includes all of the above and a spiral cutterhead.
Mine cuts like silk.
Headlock handle and actual cut thickness indicator – I added a Wixey DRO
A planer is not a replacement for a sander. Any ridges are easily sanded out because they’re so thin. A planers job is thicknessing, not finishing. Faulting it for lack of fine finish is unfair.
I finish sand everything just before assembly anyway so why gripe about it?
-- The hump with the stump and the pump!
Jeremymcon
#12 posted 04-04-2020 05:41 PM
Yes I’ll agree that the machine itself seems decent. Like the locking feature the chip blower and clear dust chute. The spiral cutter head just isn’t up to snuff. Maybe they’ll work out the machining problems eventually. But I’m sure the straight knife model is fine.
