Woodworkers Sawmill
Forum topic by Carlos510 posted 03-16-2019 06:53 AM 581 views 2 times favorited 15 replies Add to Favorites Watch
View Carlos510's profile
Carlos510
101 posts in 702 days
03-16-2019 06:53 AM
Topic tags/keywords: band sawmill
Not sure if a project like this is acceptable here, but here goes. I have wanted to build my own design of a home built band sawmill for as long as I can remember. Last summer I finally got to it. I have little need for construction length lumber. My desire is for shop project wood. For the occasional need for stud length lumber I set my maximum length to 8’6”. This will allow me to use a traveling carriage rather than a traveling arch and still limit the trailer to 18’ including the towing A frame. Here was the initial concept drawing, I like to build by the seat of my pants, according to the many salvaged parts I have collected over the years, so there is not alot of detail, but the main features are listed.
All finished except for paint, ready for a test run.
First log loaded on with the built in hoist. A lot easier than hydraulics.
Cutting a board off of a squared up Birch log.
How accurate is it? Thats a 1/16” slice of Birch veneer. Could have gone thinner still lots of strength.
Not bad for a first test run, a little less than 200 board feet. Bottom thicker boards are Poplar and Spruce, more than half are clear Birch.
All done, ready for paint.
After my test run winter came early and I didn’t get a chance for paint. The plan is to get the paint on as soon as the weather warms up again and then there is a big pile of lumber I want to saw this summer. This was a very long build with close to 300 pictures. If you would like to see the full build here is the link to my build page on my blog.
http://hobbyworkshopprojects.blogspot.com/p/sawmill-build.html
-- From popular rap:"If time is money, then I need a loan." Carlos B., http://www.hobbyworkshopprojects.blogspot.com/
15 replies so far
View TEK73's profile
TEK73
44 posts in 37 days
#1 posted 03-16-2019 07:28 AM
This is just so awsome!
Congrats on areally nice build!
-- It’s good to have an end to journey toward; but it is the journey that matters, in the end. - Ursula K. LeGuin
View Redoak49's profile
Redoak49
3881 posts in 2318 days
#2 posted 03-16-2019 10:59 AM
Amazing job and impressive sawing capability.
View John Smith's profile
John Smith
1752 posts in 492 days
#3 posted 03-16-2019 11:21 AM
WOW – with just the sketch drawing as the only image on my screen while
I read your post – I was blown away that you have actually BUILT the thing !!!
that is simply awesome and very worthy of every praise you receive on it.
all the best and hope it serves you well for many, many years.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Carlos510
#4 posted 03-16-2019 03:45 PM
Thank you for the kudos everyone, it was a project long in the back of my mind. The results were great, we’ll see how it holds up this summer.
View SMP's profile
SMP
607 posts in 235 days
#5 posted 03-16-2019 04:11 PM
Well I have to say i am jealous! Great job! I always enjoy watching lumberjack/logging shows on TV. I picture my retirement involoving something like this maybe on a smaller scale. Thanks for sharing!
View GR8HUNTER's profile
GR8HUNTER
5828 posts in 1042 days
#6 posted 03-16-2019 04:15 PM
cool tools GREAT JOB :<))
View JCamp's profile
JCamp
953 posts in 880 days
#7 posted 03-16-2019 04:46 PM
Man that’s awesome. That’s the type of project that is excepted here along with a lot of excitement and praise cause that machine is awesome.
Your lending it out to the folks on LJs right? Lol
-- Whatsoever thy hand findeth to do, do it with all thy might
View oldnovice's profile
oldnovice
7469 posts in 3698 days
#8 posted 03-16-2019 05:39 PM
That’s a really well designed and, obviously good working saw mill!
Nice job, start to finish.
View ralbuck's profile
ralbuck
5904 posts in 2596 days
#9 posted 03-16-2019 06:28 PM
A fine job!
I am sure others are going to want you to make them some too. GOOD LUCK on a fine machine!
Many of what we now consider normal things were made because someone saw the need.
The first “Bobcat” skid loaders were built on a farm near Foxhome MN because the turkey growers wanted a more nimble thing than a loader tractor for cleaning the barns. It had also to light enough to be usable in the converted hay lofts that were being used for raising turkeys. The problem landed in the capable brains of Cyril & Louis Keller; the rest id history. Evolution took the original 3 wheel design to short tandem and now eventually to semi- tracked and full tracked skid loaders.
The Kellers sold the patent eventually to Melrose that was a ND agricultural manufacturer. Then it was purchased by other companies and became a worldwide; extremely versatile use machine. Now many manufactures make very similar machines, from small enough to fit in a pickup box to huge enough to use logging.
I have driven and worked with several of these machines and marveled many times about how wonderful and usable they are. We even have one of the very small ones. It has a small 2 cylinder Honda engine and over tire rubber tracks. It is capable off fitting through a garden gate and is also able to slug right through mud that walking through is a problem.
It is fully hydraulic using hydraulics for everything.
It has since this picture was taken been totally gone through. New engine and a total new look—grey powder coated. The only way to really appreciate this machine is to have used it. The attachments that we have for it are, bucket, carrier, trencher, post hole digger—Can dig 4 ft deep with the adapter that I made, a trailer hitch receiver to put trailers in tight spaces, and the roto-tiller that I had adapted to it.
-- Wood rescue is good for the environment and me! just rjR
runswithscissors
3006 posts in 2355 days
#10 posted 03-17-2019 01:26 AM
What did you use for wheels?
Carlos510
#11 posted 03-17-2019 02:54 AM
Hi rws, I had a Chevy Cavalier that I was ready to scrap, I documented on my blog where I took it apart salvaging everything I had potential use for, leaving only the sheet metal, glass, foam and fabrics to haul to the scrap yard. I removed the wheels and rear axle complete and sized the saw frame to accept it. By removing the shocks and rotating the frame parallel to the ground, the saw frame runs low to the ground, making for easier log loading. Fabricated the front mounts to match the Cavalier and bolted the rear shock mounts to the saw frame with 1” thick hard rubber gaskets to avoid metal to metal contact. Maybe more info than you wanted.
Dont’t run with scissors but you probably know that. (smiley)
View Woodknack's profile
Woodknack
12729 posts in 2710 days
#12 posted 03-17-2019 04:45 AM
Looks like a good machine. I’ll check out the blog.
View OleGrump's profile
OleGrump
213 posts in 674 days
#13 posted 03-17-2019 05:13 PM
Congratulations on an EXCELLENT design and build. GREAT MACHINE! You can probably pick up some side work milling for others as well. OUTSTANDING! Thank you for sharing this with us.
-- OleGrump
Carlos510
#14 posted 03-17-2019 05:28 PM
Greatly appreciate all the kudos everyone. I will cut project wood for everyone here who is in arms reach of the great white north up here. (smiley)
View BFamous's profile
BFamous
312 posts in 450 days
#15 posted 03-17-2019 08:14 PM
Way cool, and I’m definitely jealous.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
