Bench Vise Advise
Forum topic by Ceick posted 03-15-2019 01:59 AM 152 views 0 times favorited 4 replies Add to Favorites Watch
View Ceick's profile
Ceick
7 posts in 373 days
03-15-2019 01:59 AM
Good evening.
As I have mentioned previously I am new to the woodworking community; almost a year now. As I continue to add items to my shop I continue to seek counsel from others with far more expierence than me. At my age, 57, I am trying to make good purchases. I do not have a vise and am considering the front vise by Rockler and Veritas front vise by Lee Valley. I really would like the Veritas; however, not sure if it is worth the money over the Rockler. It appears that they are both good units. Any advice on these units would be appreciated. Please let me know if there are others that I should consider as well.
Thank you in advance for your assistance.
Craig
View SMP's profile
SMP
482 posts in 208 days
#1 posted 03-15-2019 02:01 AM
Can you specify which ones? They both have a few.
Ceick
7 posts in 373 days
#2 posted 03-15-2019 02:09 AM
Sorry about that. I am looking at what they call the front vise. Please let me know if i need to post any additional information.
Thank you
Craig
View Wintergreen78's profile
Wintergreen78
14 posts in 42 days
#3 posted 03-15-2019 05:17 AM
If you don’t want to spend too much, I got the regular front vise from lee valley (not the Veritas branded one) and am satisfied with it. It isn’t quick release, but it holds work securely. It looks like they are $65. Making sure the face of the jaws is parallel to the bench top and that they close up at the top first is important.
View SMP's profile
SMP
#4 posted 03-15-2019 05:34 AM
Personally if I had the money I would get this
https://www.toolsforworkingwood.com/store/item/MS-VISE.XX/Milwaukee_Quick_Release_Bench_Vises_-_Made_in_USA
As i try to buy USA when possible. The other 2 options i considered for my recent bench build are the Eclipse that Paul Sellers uses
https://www.amazon.com/Eclipse-Quick-Release-Woodworking-Vise/dp/B016DNZDTU?th=1&psc=1
But I am cheap and broke so went with the Yost on Amazon that was cheap and works perfectly. No complaints
https://www.amazon.com/Yost-Tools-F9WW/dp/B01M60Q4NN?th=1&psc=1
On the yost I did take 600 grit wet dry paper and wet sanded the screw and all moving parts to polish all the edges, filing first where needed. After this hour of polishing it works much smoother than when i got it. No quick release, but i usually work with 3/4 stock, sometimes 6/4 or 8/4, but that only takes maybe 4 more seconds.
