Finishing 1/4 sawn white oak
Forum topic by AWood posted 03-13-2019 06:44 PM 299 views 0 times favorited 9 replies Add to Favorites Watch
View AWood's profile
AWood
52 posts in 4046 days
03-13-2019 06:44 PM
I am building a mess of 1/4 oak furniture. I was thinking of fuming the pieces in the traditional method of ammonia vapour (well explained on the net) However I have seen a couple of products describing finishes similar to the method of vapour fuming. Specifically a product called Odie’s Dark and another Rubio Monocoat called FMC Fumed. Has anyone used the products and what results did they get?
Would appreciate any insight!
-- AllWood
9 replies so far
View CWWoodworking's profile
CWWoodworking
319 posts in 479 days
#1 posted 03-13-2019 07:21 PM
I played around with Rubio once. It wasn’t mind blowing but a little different look than your standard stain.
Personally, I would stick to my standard stain/laquer routine before trying something like Rubio again. It’s incredibly expensive for not that different of look.
White oak is a beautiful wood and doesn’t need much fuss.
Be careful if you decide to do the fuming.
View SMP's profile
SMP
477 posts in 206 days
#2 posted 03-14-2019 01:13 AM
I did a ton of research on this, and tried various methods. Fuming alone is unpredictable with commonly available ammonia, so best to use dyes in conjunction. This is the best method i have found so far.
https://www.wwgoa.com/article/an-authentic-arts-and-crafts-finish/
View BlueRidgeDog's profile
BlueRidgeDog
304 posts in 79 days
#3 posted 03-14-2019 01:42 AM
I looked at fuming and could get the industrial ammonia, but building a chamber and then the fuss just turned me off. I use a simple minwax pecan stain then hardwax oil. Not a replica for a traditional finish, but one I like and one that will age into the ideal look for me. I do like the rays to stand out a bit more.
I have three fumed pieces (antiques) and my work is not freakish next to them.
CWWoodworking
#4 posted 03-14-2019 01:47 AM
Blue, I actually like your pieces better(a lot)than the Rubio. In my limited use, it had too much green for my taste.
View Robert's profile
Robert
3316 posts in 1781 days
#5 posted 03-14-2019 07:05 PM
For popping the grain, I’ve had my best luck using dyes.
View pintodeluxe's profile
pintodeluxe
5883 posts in 3113 days
#6 posted 03-15-2019 02:31 AM
You can do so many good things with white oak finishes. My easiest recipe is Rodda #19 Fruitwood oil based stain. Cabot, Varathane, and General Finishes have similar medium bodied oil stains that work great.
I’ve also done quite a bit of furniture with a stain-over-dye technique pioneered by Jeff Jewitt. It’s a lot more work. A LOT MORE. The look is rewarding if you’re using highly figured stock. You can get an instant antique look. My favorite combo is Transtint Golden Brown dye, followed by a seal coat of shellac. Then comes the General Finishes Antique Walnut gel stain, and finally a sprayed lacquer top coat. If you decide to try it, I have a Limbert bookcase article in the current Fine Woodworking magazine FWW #274 where I used this recipe. The article describes the process.
Good luck and have fun!
View SMP's profile
SMP
#7 posted 03-15-2019 03:31 AM
- CWWoodworking
The first time I fumed QSWO i was surprised how green it got. I thought I messed up the process But then as I researched more found it was normal, hence the dyes etc. Though I also found that fuming and just a garnet shellac over really gets rid of te green and makes a nice warm brown.
View SMP's profile
SMP
#8 posted 03-15-2019 05:58 AM
I took a couple pics of some samples i did to test for my next project. Cut this piece off, stuck it in tupperware with cheap home depot ammonia that is really low % for 3 days. Came out greenish. Put a single coat of garnet shellac and you can see the result here.
Here is the back side, instead of shellac, i sanded off the green. It still has a slight greenish tint compared to the other side i shellaced:
BlueRidgeDog
#9 posted 03-15-2019 10:43 AM
If I did not have a kid in the house (and don’t get me started on why at my age I still have a kid in the house!) and a dog, I would probably fume. As it is I like the simplicity of low VOC working conditions.
