Fence not 90 to table on GCM12SD from Bosch
Forum topic by FAB posted 03-13-2019 03:43 PM 157 views 0 times favorited 2 replies Add to Favorites Watch
View FAB's profile
FAB
1 post in 222 days
03-13-2019 03:43 PM
Topic tags/keywords: bosch gcm12sd fence question
Has anyone else experienced this problem with the GCM12SD from Bosch? I bought this a week ago and noticed as I was doing some precision cuts that the fence is not 90 to the table.
-- Andy - Athens, GA
2 replies so far
View bgood's profile
bgood
35 posts in 239 days
#1 posted 03-14-2019 04:35 AM
If the fence has hardware on the end(s) or has screws(set) on the beam rail.
Hardware on the end of the fence-
Loosen and set the perpendicular with a square.
Screws on the beam, do the same.
Don;t be afraid to loosen a set of screws at a time, see what moves when you loosen them. If that doesn’t resolve your situation, try the other. Before you adjust anything you may not be sure of make a small mark with a sharpie so you could reposition it later.
View Holbs's profile
Holbs
2246 posts in 2542 days
#2 posted 03-14-2019 04:39 AM
any machine or tool in my shop gets the precision measurement treatment before first use.
