dust collection blower
Forum topic by MichaelTT posted 03-12-2019 11:35 PM 519 views 0 times favorited 14 replies Add to Favorites Watch
View MichaelTT's profile
MichaelTT
6 posts in 599 days
03-12-2019 11:35 PM
So, I am in the process of setting up shop again, after moving.
I want to build a dust collection system. In the new house, we had to replace the furnace, and instead of throwing it away, I kept the blower from the old system.
Would this work as a blower for a dust collection system with a cyclone dust separator?
Provided of course, a proper shroud for the suction.
Pics of the blower :
14 replies so far
View Holbs's profile
Holbs
2246 posts in 2542 days
#1 posted 03-12-2019 11:38 PM
nope
View WhyMe's profile
WhyMe
1181 posts in 2074 days
#2 posted 03-13-2019 12:53 AM
Double nope. But could be used for air filtration box.
View WoodenDreams's profile
WoodenDreams
749 posts in 424 days
#3 posted 03-13-2019 02:58 AM
+1 for the air filtration system, make the box and the air filter could be a premium furnace filter to your size.
View Phsntdawg70's profile
Phsntdawg70
3 posts in 223 days
#4 posted 03-13-2019 04:59 AM
Been there done that….only kinda worked….but not worth it as a DC….maybe as an air filtration system. It won’t build enough suction to pull sawdust away from a tablesaw, jointer, or planer to keep the hose or duct from plugging.
View CaptainKlutz's profile
CaptainKlutz
1898 posts in 2007 days
#5 posted 03-13-2019 09:19 AM
+1 No. Not enough suction pressure to be useful for dust collection.
If you decided to use the blower for shop air filter, make sure to check motor voltage on name plate. Majority of Heating + AC system blowers use 220/240V rated motor. Typically want a blower from a gas furnace only unit if you want a 120V rated motor. Nothing wrong with making a 240v air filter, as long as you have an extra 2 pole circuit for it.
5760 posts in 3006 days
#6 posted 03-13-2019 10:45 AM
One more time: nope!
MichaelTT
6 posts in 599 days
#7 posted 03-13-2019 12:39 PM
OK, thanks for the answers !
Not really what I wanted to hear , but at least it will save me the time I would have spent building a shroud for it, and setting the whole thing up…
WhyMe
#8 posted 03-13-2019 01:38 PM
If you think about it all the saw dust and wood chips will get pulled throught the motor and plus the design of the squirrel cage fan cannot pass the heavy wood particles. Dust collectors use fan blades just like leaf vacuums and the motors are isolated from the air flow.
MichaelTT
6 posts in 599 days
#9 posted 03-13-2019 02:10 PM
Well, as already mentioned, I will follow the advice given by the previous posters, and not go ahead with it..
However, since I would have bee using this thing behind a cyclone, wood chips and dust being pulled through the blower/motor wouldn’t be that much of an issue
WhyMe
#10 posted 03-13-2019 06:47 PM
However, since I would have bee using this thing behind a cyclone, wood chips and dust being pulled through the blower/motor wouldn t be that much of an issue
- MichaelTT
Yeah… you just keep thinking that. The cyclone doesn’t remove the fine particles and the blower motor you have is designed to run behind an air filter. The dust getting through the cyclone would clog up the motor after time causing it to overheat and eventually killing the motor. Plus I doubt that blower has enough pull to operate a cyclone properly.
View ibewjon's profile
ibewjon
1007 posts in 3306 days
#11 posted 03-13-2019 08:38 PM
Killing the motor is not the big problem. The possible fire caused by an overheated motor in the wrong environment is the biggie. It is an open frame motor designed for use in a filtered, clean airstream.
View fivecodys's profile (online now)
fivecodys
1493 posts in 2149 days
#12 posted 03-13-2019 09:58 PM
- WoodenDreams
+2
-- When you leave your shop for the night, make sure you can always count to 10.
View MSquared's profile
MSquared
727 posts in 427 days
#13 posted 03-13-2019 11:38 PM
+3.
They’re good for moving filtered air in a plenum. They are not high-volume air movers.
-- Marty, Long Island, NY
View MikeDilday's profile
MikeDilday
259 posts in 972 days
#14 posted 03-14-2019 03:45 AM
Probably not. You need a few HP to collect dust.
-- Michael Dilday, Suffolk, Va.
