Need splitter for ridgid table saw ts3650
Forum topic by SlipKid posted 03-10-2019 09:32 PM 589 views 0 times favorited 8 replies Add to Favorites Watch
View SlipKid's profile
SlipKid
2 posts in 222 days
03-10-2019 09:32 PM
I resently purchased a Ridgid table saw TS3650 for $200.00, in excellent shape. I know the reviews of this saw are mixed but for this price it was worth it for me. Only issue is it’s missing the splitter. Any ideas of what I can do to replace it. I looked at the micro jig system using those small tabs installed after the blade.
Any suggestions
Thanks
8 replies so far
View syenefarmer's profile (online now)
syenefarmer
540 posts in 3590 days
#1 posted 03-10-2019 11:18 PM
I would do a little more research and don’t just take my word for it but I believe this will work on your saw, https://www.ebay.com/itm/Craftsman-Table-Saw-Blade-Guard/143159130179?hash=item2154f2f843:g:xcIAAOSw0AFcfkaO
View Dakkar's profile
Dakkar
355 posts in 2437 days
#2 posted 03-10-2019 11:41 PM
I’m guessing my “splitter” you mean whast Ridgid calls “Spreader Assembly” ( # TH1010 ) in their parts list. Their website lists the part as no longer available, but I’d start by watching eBay, where tool parts turn up now and then. You can look at a diagram of it on their parts page: https://ridgid.ordertree.com/catalog/partslist/view/groupid/235176/?assembly=Blade%2BGuard%2BAssembly&assemblyid=51146 .
If you’re game for some metal work you might fab something like it from sheet stock. It looks ver similar to many other spreaders I’ve seen on small saws, so it might be easy enough to adapt one made for different model. I think that’s what I’d do.
You can use to saw without one, as we did for decades before they makers started putting them on saws. If so I would abide by my first rule of table sawing: keep your vital parts out of the line of rotation on the blade. That way if something does kick back it won’t hurt you, at least.
SlipKid
2 posts in 222 days
#3 posted 03-10-2019 11:58 PM
The splitter on eBay looks like a good fit.
I am missing the bracket as well or I could maybe make the top sheet metal piece myself.
Thanks for the replays guy’s.
View EdDantes's profile
EdDantes
74 posts in 420 days
#4 posted 03-11-2019 12:08 AM
You could also look at Shark Guard. Link
View jonah's profile
jonah
2079 posts in 3808 days
#5 posted 03-11-2019 01:16 PM
The MicroJig system is going to be the cheapest option, and they work quite well, so long as you get the holes drilled properly.
View ChefHDAN's profile
ChefHDAN
1459 posts in 3359 days
#6 posted 03-11-2019 01:50 PM
Kid, I’ve got the same saw & my splitter/guard has been on a shelf for nearly 20 years now. If you need specs/pics for any of it I can send you those. I’ve also got the micro jig splitter system sitting on a shelf also unused. I have a wide variety of push sticks and various feather boards that do get LOTS of use. I’d suggest you get Kelly Mehler's book You’ll need to go through the saw from top to bottom to check all functioning parts and ensure proper alignment for safe function. The book also has quite a bit about safe process and procedures. As you hone you skill and become comfortable with the saw you’ll understand why the splitters are always off of the saws.
View toolie's profile
toolie
2168 posts in 3138 days
#7 posted 03-11-2019 02:21 PM
Kid, I ve got the same saw & my splitter/guard has been on a shelf for nearly 20 years now. If you need specs/pics for any of it I can send you those. I ve also got the micro jig splitter system sitting on a shelf also unused. I have a wide variety of push sticks and various feather boards that do get LOTS of use. I d suggest you get Kelly Mehler s book You ll need to go through the saw from top to bottom to check all functioning parts and ensure proper alignment for safe function. The book also has quite a bit about safe process and procedures. As you hone you skill and become comfortable with the saw you ll understand why the splitters are always off of the saws.
- ChefHDAN
Wow! I’m sure this comment regarding splitters was well intentioned but it’s contrary to every single authoritative comment I’ve ever seen regarding safety and table saws.
ChefHDAN
#8 posted 03-11-2019 03:12 PM
Wow! I m sure this comment regarding splitters was well intentioned but it s contrary to every single authoritative comment I ve ever seen regarding safety and table saws.
- toolie
Is that why your avatar shows two TS without splitter/guards?
