Router Table Dust Collection questions
Forum topic by newwoodbutcher posted 03-07-2019 10:48 PM 716 views 0 times favorited 6 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
794 posts in 3354 days
03-07-2019 10:48 PM
I’m building a stand alone router table. I have purchased the Bench Dog Cast Iron top and the Incra router lift I plan to build the stand with Baltic Birch Plywood and use a modified Rockler router table fence.
I’m running a central DC ((Laguna C Flux) with a 4” suction line to a shop built Dust Bucket with a branch to the fence.
I have two questions:
(1). I have seen two configurations of router table DC set ups. One configuration has a 4” line going to the dust bucket and a smaller (2 1/2’??) Line going to the fence. The other configuration I have seen has 4” lines going to both the bucket and the fence. My non technical intuition says that the latter (two 4”lines) will provide better dust collection. But most of the configurations I see have the 4” dust bucket and smaller fence set up. Can any engineer members explain which configuration is best?
(2) In researching the set up of my shop wide DC system, most recommendations were to avoid right angle turns in the piping because they reduce DC effectiveness. Yet Rockler sells a T connector for splitting the dust bucket, fence lines. Wouldn’t a Y connector be a better choice?
Thank you in advance for your responses
-- Ken
View wuddoc's profile
wuddoc
353 posts in 4222 days
#1 posted 03-08-2019 01:24 AM
View d38's profile
d38
134 posts in 766 days
#2 posted 03-08-2019 02:29 PM
I’d go 4” to both.
About a year ago, I bought an Incra router table top and made the fence and router enclosure.
I have 6” HVAC snap lock main lines coming from my 2 hp Grizzly, then a wye to 2 4” with flex hoses, so one to the fence and one to the router box.
I’m amazed how well it pulls chips off the bit.
Since you have the option, go big if you have the dust collector to support it.
View WhyMe's profile
WhyMe
1175 posts in 2065 days
#3 posted 03-08-2019 03:05 PM
........ then a wye to 2 4” with flex hoses, so one to the fence and one to the router box.
- d38
I have mine setup the same but using the Y-connector off of a main 4” hose. Works good.
https://www.rockler.com/rockler-4-to-2-1-2-dust-collection-y-connector
View Holbs's profile
Holbs
2242 posts in 2534 days
#4 posted 03-09-2019 01:49 AM
or…..
https://www.lumberjocks.com/reviews/11967
View John_'s profile
John_
213 posts in 2210 days
#5 posted 03-09-2019 02:33 AM
...use a modified Rockler router table fence…
- newwoodbutcher
I think that is your weak link. Take a look at the Incra WonderFence that does an excellent job with dust collection. I have this setup along with the Rockler ‘T’ that you mentioned and it works great
“This coupling fits both 2-1/2” dust collector and 2-1/4” shop vac fittings”
View bigJohninvegas's profile
bigJohninvegas
679 posts in 1966 days
#6 posted 03-09-2019 06:21 AM
So all of my router table dust collection is home made. I have used a single 4” hose that I split to go to both the fence, and the box. worked well, and kept everything clean.
When I made my latest router extension table I skipped making a new bucket. And only use the fence. Same 4” hose that is adapted down to 2 1/2”. My fence is the same style as the Incra wonder fence. It works almost as well with out the bucket. Very little dust makes it below the table. I do have a woodpecker router lift, with the extra rings. I keep the smallest ring possible on the router. I feel this helps.
-- John
