Constructing a table saw crosscut sled
Forum topic by jerbear74 posted 03-04-2019 06:55 PM 664 views 0 times favorited 15 replies Add to Favorites Watch
View jerbear74's profile
jerbear74
3 posts in 278 days
03-04-2019 06:55 PM
I’m seriously considering on building a crosscut/miter sled for my table saw. I’ve watched several videos on this project, in which they used CA glue to set the runners to the base. I’ve discovered that there are different types/thicknesses of this glue. My question is: which type or thickness is best for this project, and is Loctite just as good, as it is readily available ?
Thank you ,
Jerbear74
15 replies so far
View ArtMann's profile
ArtMann
1436 posts in 1329 days
#1 posted 03-04-2019 07:02 PM
What material are you using for the runners?
View John Smith's profile
John Smith
2017 posts in 675 days
#2 posted 03-04-2019 07:03 PM
I used just plain old TiteBond II for the runners on two
of my sleds and they are holding up well.
personally, I use very little CA glue and it is just for small projects.
don’t over think it.
-- I am a painter. That's what I do. I paint things --
View Davevand's profile
Davevand
128 posts in 1349 days
#3 posted 03-04-2019 07:16 PM
The CA glue is just used to tack the runner before you put screws in, I just use the cheap stuff
View pottz's profile
pottz
6389 posts in 1497 days
#4 posted 03-04-2019 07:23 PM
yeah loctite is as good as any,but i always use screws also.
jerbear74
3 posts in 278 days
#5 posted 03-04-2019 07:23 PM
ArtMann:
I forgot to mention that I’m using aluminum runners for this project.
Thank you, jerbear74
Rick Dennington
6664 posts in 3707 days
#6 posted 03-04-2019 07:26 PM
I’ve never used CA glue for the runners…I’ve built about 5 sleds, and I use 1/2” double stick tape to mount the runners onto the base…..It will hold the runners in place while you screw down the runners, be it wood or aluminum.
-- " The secret to staying young looking.....hang around old people.." R.D.
View Andybb's profile
Andybb
2112 posts in 1116 days
#7 posted 03-04-2019 10:13 PM
Use the CA to hold them in place before you screw them in or until the wood glue dries.
-- Andy - Seattle USA
John Smith
#8 posted 03-04-2019 10:39 PM
Jerbear ~ are you going to use angle or flat bar for the runners ??
if you are using aluminum flat bar for the runners, you will have to tap
threads into them to accept countersunk screws.
if the screws protrude out of the metal bar, just slice them off with
the angle grinder with a cut-off blade. a drop of Thread-Lock is suggested.
if you are going to use angle, double faced tape or CA will hold the angle
in place while you get the screws and nuts fastened.
some photos of your finished project would be nice to see !!
View PPK's profile
PPK
1527 posts in 1322 days
#9 posted 03-04-2019 10:42 PM
Yep, don’t overthink it. Screw them on, but pay most attention to making sure it’s square!!!
-- Pete
View Robert's profile
Robert
3539 posts in 1993 days
#10 posted 03-05-2019 03:45 PM
If I ever build another one, I will dado one of the runners.
View CMWx2's profile
CMWx2
27 posts in 556 days
#11 posted 03-05-2019 05:11 PM
Interesting. Why is that. So that one is dead perfect?
- rwe2156
View Guvnor's profile
Guvnor
2 posts in 226 days
#12 posted 03-10-2019 02:43 AM
When you are completely satisfied that the sled is square,plan on rabbeting one of the runners in place. This will prevent the runner from being knocked out of position whilst moving it from the saw. I personally keep one long Ipe runner on the sled and not a parallel second one. This enables me to jump one track and use it when I have the blade at 45°, one clean kerf for 90° and one clean kerf for 45°.
Whoever said you needed two runners…as long as one is properly fit and secured you will have no problem, just a thought!
Guvnor
2 posts in 226 days
#13 posted 03-10-2019 02:50 AM
When you are completely satisfied that the sled is square,plan on rabbeting one of the runners in place. This will prevent the runner from being knocked out of position whilst moving it from the saw. I personally keep one long Ipe runner on the sled and not a parallel second one. This enables me to jump one track over and use it when I have the blade at 45°, one clean kerf for 90° and one clean kerf for 45°.
Whoever said you needed two runners…as long as one is properly fit and secured you will have no problem,just a thought!
View pintodeluxe's profile
pintodeluxe
5987 posts in 3326 days
#14 posted 03-10-2019 03:37 AM
Carpet tape works to hold the runners in place until you can install the screws.
View OleGrump's profile
OleGrump
500 posts in 857 days
#15 posted 03-17-2019 05:23 PM
I kinda went the other way around. I got the maple runners as square as possible and screwed them to the base on the sled. Then ran the assembly 3/4 of the way through the table saw. Used a framing square to mark the 90 degree position for the fence (left and right of the existing kerf) then screwed the fence in place and ran the whole assembly through the saw with the blade at the maximum height which I would be using. (In my case 1 3/4 inches, so I could cut short lengths on 2X4) Simple but effective.
-- OleGrump
