How wide is too wide for a solid wood drawer?
Forum topic by Jeremymcon posted 03-03-2019 07:59 PM 412 views 0 times favorited 9 replies Add to Favorites Watch
View Jeremymcon's profile
Jeremymcon
415 posts in 1531 days
03-03-2019 07:59 PM
I’m designing a dresser for my daughter who we are expecting in June, and my wife had given me dimensions she’d like like me to build it to – 36” tall x 40 wide x 18” deep. It’s going to double as a changing table for babies first few years of life.
Issue I’m having is that in the 40” wide case I end up with drawers that are about 36”wide. I was just going to do dovetailed drawers with traditional wooden slides in a frame and panel case. I’ve. Never made a drawer 36” wide though. Is that too wide for wooden slides? Am I going to end up with wracking issues? I feel like if I divide the drawers in half they’re going to end up like 16-17” wide, which I’m more comfortable with, but then I end up with some wasted space in the case, and I have to make twice as many drawers.
9 replies so far
View Aj2's profile
Aj2
3337 posts in 2649 days
#1 posted 03-03-2019 08:38 PM
When a drawer measures wider then its depth use a center mount slide. I’ve made my own Dt center slides from good straight hard maple.
It’s a good challenge and very rewarding.
If you really want to up your skills add drawer slips to the construction.
-- Aj
View CWWoodworking's profile
CWWoodworking
1016 posts in 1030 days
#2 posted 03-03-2019 09:02 PM
undermount soft close.
Jeremymcon
#3 posted 03-04-2019 12:45 AM
Hmm… I’ve never tried center mount guides. I’m definitely going to do wooden glides. The only issue I see with the center guide is that I was planning to do inset drawers – I can’t picture how that could work without doing a lipped drawer, since there’d only be 1/4” of space to work with under the drawer bottom.
View bandit571's profile
bandit571
26488 posts in 3534 days
#4 posted 03-04-2019 12:47 AM
maybe have a look at that Blog I am doing…..about a “Chester Drawers”.....
Jeremymcon
#5 posted 03-04-2019 12:48 AM
Although… I was thinking that I’d have to divide the drawer bottom if I was going to make it that long. I could see how maybe a groove in the divider and a strip of wood on the web frame could help keep the drawer centered… Interesting.
I actually was thinking I’d try drawer slips this time too! Lol. Especially since the drawers will be so large and potentially heavy.
CWWoodworking
#6 posted 03-04-2019 01:11 AM
No problem using center guide with inset. Everything just gets moved back. If I wanted to use a wooden guide, I would do loose c channel with a tilt rail. No need to split bottom. If design allows, put pull close to or centered.
The bigger issue is this- when it’s 3 in the morning and your trying to open that drawer full of diapers, wipes, lotion, etc while holding a crying baby wishing you used blumotion you could open fully with your pinky toe. :)
I like center glides for most furniture. Most applications if done properly work really well.
This particular situation screams undermounts.
View Aj2's profile
Aj2
#7 posted 03-04-2019 01:16 AM
Hmm… I ve never tried center mount guides. I m definitely going to do wooden glides. The only issue I see with the center guide is that I was planning to do inset drawers – I can t picture how that could work without doing a lipped drawer, since there d only be 1/4” of space to work with under the drawer bottom.
- Jeremymcon
If you haven’t built the drawers yet . You can move the drawer bottom up the center mount can also be included into drawer bottom.
-- Aj
View AlaskaGuy's profile
AlaskaGuy
5993 posts in 3160 days
#8 posted 03-04-2019 01:35 AM
I’m a wide draw freak. I like them wide. I have some 4 foot wide drawer in my kitchen. I used rack and pinion drawer slides. Yes they are not cheap. The only ones I could find at the time were really over kill @ a 200 lbs capacity but I since discovered the Blum under mounts with Blum stabilizers.
This is a short video I made to show how nice they work and it makes no difference where you pull on the drawer it won’t bind.
https://www.youtube.com/watch?v=ykL8fEKRGPA
The is video is the Blum under mounts with Blum stabilizers.
https://youtu.be/0Q6Z76a8_vI
Jeremymcon
#9 posted 03-04-2019 02:38 AM
- CWWoodworking
I have no idea what “loose c channel with a tilt rail” means. Do you have a picture?
