Is a 17" Grizzly g0513 band saw as capable for fine work as a high end 14"?
Forum topic by SquareEnough posted 03-03-2019 02:39 AM 4424 views 0 times favorited 42 replies Add to Favorites Watch
View SquareEnough's profile
SquareEnough
14 posts in 695 days
03-03-2019 02:39 AM
Like many others, I’m debating a Rikon/Laguna 14” vs the Grizzly G0513X2. I get the Grizzly is a great value and has a bigger table and does a good job resawing but the two 14” have a lot of great features that lend themselves to cutting clean. I expect I’ll be splitting time between resawing and detail work. Will I be happier with the quailty of work with a Grizzly 17” or a high end 14”?
This is the last machine I need to complete the shop. Every other piece has seemed to be an obvious choice for my needs but this has had me scratching my head.
42 replies so far
View TimInIndiana's profile
TimInIndiana
161 posts in 1109 days
#1 posted 03-03-2019 02:45 AM
One important consideration – are you able to properly supply electrical for the G0513X2? It requires a 30A circuit at 110V (15A at 220V).
View DMiller's profile
DMiller
541 posts in 1442 days
#2 posted 03-03-2019 02:49 AM
I’d saw go with the Laguna 14/12. I purchased one recently and it does a great job of resawing and scrolling.
-- Dale Miller Modesto, CA "I can do all things through Christ, which strengtheneth me." Philippians 4:13. "Woodworking minus patience equals firewood."
SquareEnough
#3 posted 03-03-2019 02:51 AM
- TimInIndiana
Yeah, good call though. I ran a 75 amp subpanel to the garage. Powers my 8” Rockwell jointer, tablesaw, brewing system, etc.
View Andybb's profile
Andybb
3046 posts in 1573 days
#4 posted 03-03-2019 02:54 AM
LAGUNA!!! I am a huge fan. Took me a year of research before I bought. Here’s my short and sweet video and my review.
You will not be dissapointed. Promise.
-- Andy - Seattle USA
TimInIndiana
#5 posted 03-03-2019 02:55 AM
- SquareEnough
I’m certainly not an electrician, so take what I say with a grain of salt. But my understanding is that you’ll want to pull 10 AWG wire for the 30A circuit if you don’t have it already.
View BlueRidgeDog's profile
BlueRidgeDog
787 posts in 748 days
#6 posted 03-03-2019 02:58 AM
I got the 17” griz. Love it. Can’t imagine wanting or needing another saw. Power, table size, space, capacity…it has it all.
I will take as fine a blade as the smaller, but will also take bigger. I could see me getting a 14” just to have two setup at one time, but I love being able to run the big blades for resaw.
SquareEnough
#7 posted 03-03-2019 03:03 AM
- SquareEnough
I m certainly not an electrician, so take what I say with a grain of salt. But my understanding is that you ll want to pull 10 AWG wire for the 30A circuit if you don t have it already.
- TimInIndiana
Yeah, I tend to do everything over code. A few extra bucks is worth the peace of mind.
View Ceick's profile
Ceick
15 posts in 1039 days
#8 posted 03-03-2019 03:10 AM
Good evening from NC . I am in the same position regarding the purchase of a bandsaw I am new to woodworking and at my age, 57, I am attempting to save my pennies and only by once. I have read countless reviews and looked at both Rikon and Laguna. I think i am going to go with the Laguna 14 bx 220V 2.5 HP. I enjoy buying rough lumber and milling it myself. I wanted a machine that i could use for resawing as well as other needs. I have 220 in my shop for my table saw and jointer that I have yet to purchase.
Given that I am new to the woodworking world any guidance/thoughts is welcome and appreciated.
Thank you in advance.
View jimintx's profile
jimintx
934 posts in 2554 days
#9 posted 03-03-2019 03:18 AM
I went through this and chose the Rikon 10-326.
I really prefer its guide system over the other two saws.
I have great 220v all over my shop, but I decided to get the 120v Rikon and it is simply fantastic.
I wanted to buy my saw locally, so I did not seriously consider an order from Grizzly.
I looked at and played around some with Rikon, Laguna, and Jet options.
-- Jim, Houston, TX
SquareEnough
#10 posted 03-03-2019 03:20 AM
- jimintx
Interesting, what do you like about the guide over the Laguna?
View onoitsmatt's profile
onoitsmatt
447 posts in 2145 days
#11 posted 03-03-2019 04:00 AM
Yeah I’m interested to hear about the Rikon too. I have the Rikon and hate the bearing guides for scroll work. Maybe I’m doing something wrong. I had an old 1950s Delta 14” that was great for scroll work but the Rikon bearing guides are too fiddly to get dialed in well for it.
-- Matt - Phoenix, AZ
View Gittyup's profile
Gittyup
210 posts in 2926 days
#12 posted 03-03-2019 04:22 AM
I own a G0513X. Love it. The size cannot be underestimated. I’m sure other 17”+ saws are also quite good. But a 14” will limit you more than you might think. I also own a 14” . I have it set up with a carter guide and a 1/4” blade. I keep the Grizzly setup for resawing. But, on several occasions I’ve add to change out the resaw blade to a smaller blade when the pieces I was cutting were too big for my 14”. The rise on some 14” saws will also limit your resawing. Tough call, but if I could only have one, it would be bigger not smaller.
-- tel
SquareEnough
#13 posted 03-03-2019 04:43 AM
Do you feel like you can do scroll work with the g0513x when necessary?
BlueRidgeDog
#14 posted 03-03-2019 12:25 PM
- SquareEnough
easily. A big saw is not “bad” at small work (IMHO). A big saw can do small work and big work. A small saw can do small work.
View Redoak49's profile
Redoak49
5023 posts in 2958 days
#15 posted 03-03-2019 02:08 PM
One question is what kind of work you will be doing.
I have a 16” Jet for resaw. I also do scroll saw work and wanted a small bandsaw. I bought the 10” Rikon to run 1/8” and 3/16” blades using a Carter Stabilizer. I can do things with it that you can not do with a larger bandsaw.
showing 1 through 15 of 42 replies
