Identifying the wood
Forum topic by Young posted 03-02-2019 05:26 PM 415 views 0 times favorited 13 replies Add to Favorites Watch
View Young's profile
Young
20 posts in 1489 days
03-02-2019 05:26 PM
I need help to identify this wood species. This is one of leg for dining table and I need to make two legs which was damaged by dog’s bite. Thank you for your help in advance.
-- Young, California, http://www.inhimstudio.com
13 replies so far
View Dutchy's profile
Dutchy
3423 posts in 2676 days
#1 posted 03-02-2019 05:32 PM
Can you post some close up pictures?
-- https://dutchypatterns.com/
View Aj2's profile
Aj2
2480 posts in 2305 days
#2 posted 03-02-2019 07:47 PM
Figuring out the wood is the least of your problems. Unless your a finishing pro.
Clearly it’s some inexpensive white wood laminated together.
Good Luck
-- Aj
View OnhillWW's profile
OnhillWW
186 posts in 1740 days
#3 posted 03-02-2019 08:15 PM
You could just cut smooth and glue on a blank, carve and stain to match. De3pending on the quality of the table my WAG is Maple or Tulip Poplar.
-- Cheap is expensive! - my Dad
View Rich's profile (online now)
Rich
4976 posts in 1097 days
#4 posted 03-02-2019 09:45 PM
- OnhillWW
+1. I believe it’s also a candidate for rebuilding with epoxy putty.
-- There are 10 types of people—those who understand binary, and those who don’t
Young
#5 posted 03-03-2019 04:30 AM
here is more closer picture
View Lazyman's profile
Lazyman
3948 posts in 1895 days
#6 posted 03-03-2019 05:15 AM
I would try to rescupt it from some Bondo wood filler. If you really want to remake it, since it is a light wood and obviously stained, it doesn’t really matter what kind of wood it is just pic s light wood, and work on getting the stain color right. Of course, If you use the Bondo, you’ll need to do that too.
View bondogaposis's profile
bondogaposis
5540 posts in 2859 days
#7 posted 03-03-2019 01:32 PM
It looks like soft maple to me.
-- Bondo Gaposis
View BlueRidgeDog's profile
BlueRidgeDog
499 posts in 287 days
#8 posted 03-03-2019 02:48 PM
Maple or ash (looking at the fibers) but either would work. For the repair you could also use clear poplar that is easy to get at the big box stores. Personally, I would flatten out the chewed area and glue on a few blocks of wood then shape it. Good project…will be a challenge.
117722 posts in 4084 days
#9 posted 03-03-2019 03:11 PM
If you’re really going to remake it then any hardwood will work that you can get a color match assuming you have the finishing skills.
Young
#10 posted 03-03-2019 11:48 PM
Thanks for all you guys advises. I would use ash or poplar for re-building the part.
20575 posts in 2364 days
#11 posted 03-04-2019 12:54 AM
Soft maple was also my guess. I concur with Bondo.
View JCamp's profile
JCamp
1004 posts in 1058 days
#12 posted 03-04-2019 01:03 AM
I’d suggest using poplar or just pine cause it’s easier to work with. Strength isn’t a issue cause it’s not weight bearing or structural it’s just a cosmetic piece. I’d flatten and glue in a close matching blank then use knives or a drimel to carve to whatever looks good. Color matching will be the hard part but it helps that most of the time folks don’t look at the feet of a table. Good luck
-- Whatsoever thy hand findeth to do, do it with all thy might
View pontic's profile
pontic
697 posts in 1116 days
#13 posted 03-04-2019 03:14 AM
I say it’s popular. Get a grinder file and and old saw blade and make a moulding scraper and add a new chunk of popular and shape it with the scraper with the profile you just ground in to it. It is a veery common treatment for tables and if they keep the dog you will be using it again.
-- Illigitimii non carburundum sum
