Looking for a good scrollsaw
« back to Scrollsawing forum
Forum topic by annis posted 03-02-2019 03:14 PM 619 views 0 times favorited 10 replies Add to Favorites Watch
View annis's profile
annis
7 posts in 83 days
03-02-2019 03:14 PM
‘m looking for a scroll saw that I can place a nickle(US) on edge on the table and it not fall over even at full speed. I think the Excalibre or King industries 16” might be a possibility also. I don’t know the Jet might be good also.
There is so much confusion about these saws right now. Distributor is not the same as manufacturer. I think that all these saws are made in China or Taiwan. Not to diss these countries, they an make good equipment if that is what the distributor wants.
The experience I’ve had with scroll saws is that when turned on, they would walk off the table….Even when bolted down!
10 replies so far
View Redoak49's profile
Redoak49
3926 posts in 2350 days
#1 posted 03-02-2019 05:10 PM
Try a Hegner but it is expensive.
You might try the forum at Scroll Saw Village and get a lot of help. Edit: I see you already posted same question there.
View JethrowClampett's profile
JethrowClampett
22 posts in 104 days
#2 posted 03-02-2019 05:37 PM
Look at PS Wood Machines – 21” is made in Pennsylvania. Heavy Duty Machine with manual belt speed change (don’t have to worry about variable speed controllers failing). They carry all of the spare parts. Look at the video’s on u-tube to get a better idea. Yes they are a little expensive, but comes with stand and blades and is made to last. They also have a web site https://pswood.com.
-- Jethrow
View pvw's profile
pvw
3 posts in 31 days
#3 posted 04-22-2019 01:02 PM
we had a Hegner and its not gonna do it for you.
Best bet is a Seyco , excaliber or jet. We have all three of those and preference is in that order.
mike
Redoak49
#4 posted 04-22-2019 02:03 PM
My Hegner was made in 1996 and runs very smooth.
A good question is what are you going to use it for. Some are easier to thread a blade from the top or bottom.
View Phil32's profile
Phil32
534 posts in 265 days
#5 posted 04-22-2019 03:18 PM
Why is standing a nickel on the table your criteria? It should be the effectiveness of the scroll saw at performing the task you are doing.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View MrRon's profile
MrRon
5439 posts in 3605 days
#6 posted 04-22-2019 06:43 PM
It may be possible to have a scroll saw that can run vibration less, but once you start cutting, vibration will begin.
View WoodenDreams's profile
WoodenDreams
582 posts in 273 days
#7 posted 04-23-2019 07:29 PM
At the local woodworkers club, they all have the DeWalt Scroll Saw. most of them do very intracit work.
View TungOil's profile
TungOil
1208 posts in 857 days
#8 posted 04-24-2019 02:50 AM
Any reciprocating saw will have some perceptible vibration, it’s the nature of the beast. I have a 22” Hegner and it runs very nicely, made in Germany.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Peter101's profile
Peter101
9 posts in 111 days
#9 posted 04-24-2019 09:44 AM
- Redoak49
I second this one.
hegner scroll saws are top drawer.
expensive – but excellent for precision work.
View Carlos510's profile
Carlos510
270 posts in 734 days
#10 posted 04-24-2019 01:26 PM
As TUNGOIL said it’s the nature of the beast, the best machine out there will vibrate at higher speeds if there is an eccentric in the drive to produce reciprocating motion, more pronounced the higher speed you go. Excalibur’s best machine had rave reviews when it came out, don’t know if it’s still in production. The European Hegner is also considered top of the pile. You will pay big time for the extra balancing that goes into these machines to reduce vibration.
As for the nickel you may never find a jigsaw that passes that test at higher speeds. That test is more commonly used for none reciprocating drives like a table saw or other rotary application.
-- "If time is money, then I need a loan" , http://www.hobbyworkshopprojects.blogspot.com/
