Table apron tenon length
« back to Joinery forum
Forum topic by JerryLH posted 03-01-2019 10:54 PM 605 views 0 times favorited 11 replies Add to Favorites Watch
View JerryLH's profile
JerryLH
196 posts in 1991 days
03-01-2019 10:54 PM
Topic tags/keywords: question mahogany joining
I have a question good folk concerning tenon length and thickness. I’m making a dinging table of mahogany – The legs are glued up 3.75” x 3.75” – The apron material is 15/16” x 4-5/8”. I’ll be cutting the mortise with a mortising machine. My thought is 3/8 or 1/2” thick tenon & I’m not sure at all about the tenon length. Is there a rule of thumb as to how far the tenon should extend into the leg? Thanks
-- Develop your character -- for it becomes your destiny. Jerry - Mannford, Ok
11 replies so far
View bondogaposis's profile
bondogaposis
5684 posts in 3031 days
#1 posted 03-01-2019 11:34 PM
I’ll be interested to find out what dinging table is used for. To answer your question I would make the mortise 3/8” wide and as long a possible into the leg. It is ok for the mortises to intersect and you can 45° the ends of the tenons where they meet. That gives you the strongest possible configuration.
-- Bondo Gaposis
JerryLH
#2 posted 03-02-2019 02:31 AM
As to what a dinGing table is used for – important stuff. Thanks Mr Bondo – I appreciate your help. Good Day Sir.
View SMP's profile
SMP
1889 posts in 586 days
#3 posted 03-02-2019 02:56 AM
I ll be interested to find out what dinging table is used for.
- bondogaposis
Sounds like my first table i made out of sugar pine. How are you chopping mortises? Drill? Router? When routing i am usually limited by router bit length.
View CWWoodworking's profile
CWWoodworking
667 posts in 859 days
#4 posted 03-02-2019 03:13 AM
- bondogaposis
I’d be interested if anyone has tested this.
In theory, at some point, a longer tenon doesn’t gain anymore strength while removing more material from leg(again in theory) would weaken leg.
If the leg is hit hard enough, the leg will break, not the tenon. Regardless of length(within reason).
I liken it to using a bigger screw in joining particle board. Doesn’t matter cause the screw isn’t the weakest link.
JerryLH
#5 posted 03-02-2019 02:42 PM
Thanks Mr CW & SMP – I’ll be cutting the mortises with a mortising machine. As to Length of tenon I would tend to agree that at some point the length of the tenon doesn’t increase leg to apron strength. The tenons will also receive draw bored dowels. Thanks to all.
View fly2low's profile
fly2low
88 posts in 777 days
#6 posted 03-25-2019 02:57 AM
The rule of thirds can be violated when joining a thin board to a thicker one – apron to leg in a table is a perfect example. I would go with 1/2 thick
-- Rich Gig Harbor, WA
View WoodenDreams's profile
WoodenDreams
968 posts in 591 days
#7 posted 03-25-2019 07:54 AM
I would do 1/2” mortises, since your using a mortise machine on 15/16” rails. 3/8” mortises will work. I also would set the mortises deep as bondo says. If your still questioning structure, then also install a couple pins into each, plugging the holes with buttons.
View Robert's profile
Robert
3662 posts in 2161 days
#8 posted 03-25-2019 01:58 PM
1/2” thick mortises.
3/4” shoulder top and bottom.
2 1/2” is long enough with pins.
JerryLH
#9 posted 03-25-2019 10:52 PM
Thanks Robert – feelun pretty good – about ready to glue up legs and apron along with corner braces.
View AlaskaGuy's profile
AlaskaGuy
5594 posts in 2989 days
#10 posted 03-26-2019 03:15 PM
To confuse you ever more this is what Chris Schwarz has to say. Personally I’d do it like bondogaposis says or even a tad shorter to avoiding messing with the 45°. Either isn’t going to make or break you project. Many of tables have been made as pictured below and survived just fine.
https://www.popularwoodworking.com/chris-schwarz-blog/tenons-rule-so-here-are-the-rules-on-tenons/
JerryLH
#11 posted 03-27-2019 03:19 PM
Alaskaguy – I prefer your example. With the glues as good as they are – that tenon will never have a glue failure and leaves the upper leg a stronger piece of wood. IMO.
