Finally have dust collection done!
Forum topic by Raymer posted 02-25-2019 02:45 PM 1185 views 0 times favorited 32 replies Add to Favorites Watch
View Raymer's profile
Raymer
92 posts in 933 days
02-25-2019 02:45 PM
Well I didn’t do anything special or new, but I got my first decent dust collection setup. I bought the Harbor Freight 2HP system, the HF dust collector accessory kit, Wood River cyclone lid and 30 gallon metal trash can.
I built a simple cart from scrap I had laying around and used the casters that came with the HF DC.
HF DC: $167.00
Accesory kit: $47.00
Cyclone lid: $24.00
Trashcan: $29.00
Total cost: $267 + tax
I was also given 4 10’ pieces of 4” sewer drain which would have cost another $65, but thanks to the guys building out the new neighborhood, they said I could take them so they didn’t have to haul them back.
I tested this thing briefly on my tablesaw and after a dozen cuts or so, I couldn’t see anything in the plastic bag, all went to the trashcan.
The only issue I had initially was the 20amp breakers tripping when turning it on. I spent another $7 and replaced them with 30amp breakers and problem solved.
-- -Measure once, cut twice, cut once more for good measure.
32 replies so far
View BlasterStumps's profile
BlasterStumps
1790 posts in 1291 days
#1 posted 02-25-2019 03:14 PM
What size wire is now being fed by your new 30 Amp breaker?
-- "I build for function first, looks second. Most times I never get around to looks." MIke in CO
View JohnMcClure's profile
JohnMcClure
1087 posts in 1492 days
#2 posted 02-25-2019 03:20 PM
Great solution. I wish I’d done it that way the first time.
However the breaker upgrade is going to raise some eyebrows unless the wire it feeds is appropriate gage. The breaker protects the wire and the new breaker offers less protection.
The danger isn’t your DC, it’s the next resident who plugs in two space heaters on this 30a circuit. This could cause a fire.
-- I'd rather be a hammer than a nail
Raymer
#3 posted 02-25-2019 03:36 PM
- BlasterStumps
Do you mean the size of romex running in the wall? If that is what you mean, I believe it is 12-2, but I will double check.
BlasterStumps
#4 posted 02-25-2019 03:42 PM
Yes, the size of romex running in the wall.
Raymer
#5 posted 02-25-2019 05:10 PM
- BlasterStumps
It appears the wire in the wall from the sub panel to the outlets is 12-2…...Oops. I have turned those breakers off and will put the 20 amps back in.
So, now I am back to square one. Can I run romex through the attic and then through conduit on the wall coming through the garage ceiling? I don’t want to cut all the drywall out.
If I leave the 2 circuits at 20amp as wired and then just run a new circuit with 10-2 with a 30amp, isn’t it safe to run the romex down a wall to a metal gang box as long as it’s in conduit?
6422 posts in 3345 days
#6 posted 02-25-2019 05:26 PM
I have a different thought. A lot of folks run those HF DCs on a 120V/20A circuit with no problem. Is there something else that could be wrong? Maybe you didn’t have any ductwork connected to it and tried it out (that’s a much bigger load on the motor).
View panzer's profile
panzer
7 posts in 1211 days
#7 posted 02-25-2019 06:16 PM
- BlasterStumps
So, now I am back to square one. Can I run romex through the attic and then through conduit on the wall coming through the garage ceiling? I don t want to cut all the drywall out.
If I leave the 2 circuits at 20amp as wired and then just run a new circuit with 10-2 with a 30amp, isn t it safe to run the romex down a wall to a metal gang box as long as it s in conduit?
- Raymer
You really aren’t supposed to run romex in conduit. A easier solution would be to run type MC cable. It is it’s own flexible metal conduit and should be fine exposed in this application. Check your local codes though.
View HokieKen's profile
HokieKen
15067 posts in 1990 days
#8 posted 02-25-2019 06:20 PM
- BlasterStumps
- Raymer
Yes, you can run the wire through your attic and drop it via conduit to a gang box. At least you can here in VA… Code differs by location though so you might want to verify.
Fred brings up a good point though. You should not be throwing a 20A breaker with your HF blower. Is that the only thing running on that circuit?
If you really do need a 30A, it would be highly unusual in my experience to have a 115V circuit that large. Seems like something is over-loading the blower. Or maybe your 20A breaker is just faulty and you need to replace it with a new 20A breaker? Maybe a slow-tripping variety to allow for the startup inrush current?
-- Kenny, SW VA, Go Hokies!!!
Raymer
#9 posted 02-25-2019 06:31 PM
I have a different thought. A lot of folks run those HF DCs on a 120V/20A circuit with no problem. Is there something else that could be wrong? Maybe you didn t have any ductwork connected to it and tried it out (that s a much bigger load on the motor).
- Fred Hargis
This….yes, it was throwing the breakers, but I didn’t have any ductwork up yet. Didn’t realize that could be a problem.
#10 posted 02-25-2019 07:24 PM
What happens is the blower is trying to move much more air than it will with the ductwork attached, maybe 2-3 times as much. That would be on top of the bug start up load that the DC has anyway (spinning up that impeller puts a big draw on the circuit.). So all that puts such a load on the motor it will draw enough amps to trip the breaker. If you want to test it, cover the inlet with something and then turn it on. In this case it shouldn’t be moving any air and the motor will essentially loafing along and not drawing too many amps.
View fivecodys's profile
fivecodys
1647 posts in 2487 days
#11 posted 02-26-2019 12:27 AM
Another thought. Maybe replace the breaker with a new 20 Amp breaker. Could just be a bad breaker.
Just my 2 cents.
-- A bad day woodworking is still better than a good day working.
View WhyMe's profile
WhyMe
1309 posts in 2412 days
#12 posted 02-26-2019 12:40 AM
If you are using an extension cord, get rid of it. Extension cords cause voltage drop which increases amps. DC should plug directly into wall outlet.
Raymer
#13 posted 02-26-2019 01:00 AM
Just my 2 cents.
- fivecodys
Good idea, I’ll do that tomorrow, they’re cheap, might as well.
Raymer
#14 posted 02-26-2019 01:02 AM
- WhyMe
Even using a short 12ga extension cord isn’t good? Where I have a place for my DC, there is no outlet within reach.
WhyMe
#15 posted 02-26-2019 01:23 AM
#12 short cord should be fine. If short is 10 – 12ft. I know the manual states what cord can be used but my experience with motor loads, extension cords can cause problems.
showing 1 through 15 of 32 replies
