New Harbor Freight Dust Collector - they improved it?!?
Forum topic by Raymer posted 02-23-2019 03:12 PM 1226 views 0 times favorited 10 replies Add to Favorites Watch
View Raymer's profile
Raymer
92 posts in 1291 days
02-23-2019 03:12 PM
I just bought a new HF 2HP dust Collector and am modding it with the Wood River cyclone lid into a 30 gallon trash can.
One of the things I read about some people upgrading is the impeller, changing it from the plastic impeller to a metal one. Well I am starting to build this today and when I unpacked it all, I discovered that it already has a solid metal impeller.
This unit looks slightly different from some of the others I have seen that they sold previously. Anyway, I used a 20% coupon and got it for $167, then spent another $50 for the cyclone lid and trashcan.
-- -Measure once, cut twice, cut once more for good measure.
10 replies so far
118201 posts in 4786 days
#1 posted 02-23-2019 03:22 PM
Interesting,thanks for the info.
View jamsomito's profile
jamsomito
682 posts in 1635 days
#2 posted 02-23-2019 03:30 PM
I thought the impeller was always metal, it’s just 9 inches. The upgrade was to a bigger one from rikon that gave more airflow. Maybe I’m wrong though.
View WhyMe's profile
WhyMe
1409 posts in 2770 days
#3 posted 02-23-2019 03:38 PM
I did the impeller upgrade. The orginial is 10”, new is about 12”. None of the orginial impellers were ever plastic as far as I know.
21481 posts in 3066 days
#4 posted 02-23-2019 03:48 PM
I have a Delta DC that the motor burned up. I’m either going to use motor from my HF to get the delta going again or try to put the delta impeller in the HF. I don’t even know which is possible, but I imagine I will just try to put the HFmotor on the Delta DC.
Raymer
#5 posted 02-23-2019 04:08 PM
I thought the impeller was always metal, it s just 9 inches. The upgrade was to a bigger one from rikon that gave more airflow. Maybe I m wrong though.
- jamsomito
You might be right, but could have swore I saw before they were plastic, if not, my bad for pointless post…
View WoodenDreams's profile
WoodenDreams
1408 posts in 1120 days
#6 posted 02-23-2019 04:58 PM
Still info for us
WhyMe
#7 posted 02-23-2019 09:10 PM
I can’t imagine that a plastic blade would hold up. I’ve had a few chunks of wood pass through my dust collector that would have wreaked havoc on a plastic blade.
View Dustin's profile
Dustin
707 posts in 1949 days
#8 posted 02-24-2019 12:11 AM
- jamsomito
- Raymer
I bought mine about 3 years ago, it was metal then, too. Just undersized (I upgraded to the Jet impeller…required me boring out the shaft, but it worked).
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
Raymer
#9 posted 02-24-2019 01:28 AM
- jamsomito
- Raymer
- Dustin
How did it work out? Notice much difference? Cause any issues with the motor over time?
WhyMe
#10 posted 02-24-2019 03:39 AM
There are threads on the mod of HF dust collector with the Rikon impeller. It does increase suction but increases the load on the motor. Mine is doing okay and hasn’t killed the motor…. yet.
