Drill bits
Forum topic by plang posted 02-21-2019 04:54 PM 681 views 0 times favorited 12 replies Add to Favorites Watch
View plang's profile
plang
137 posts in 4272 days
02-21-2019 04:54 PM
Where might I find a 1/32 inch drill bit with a 1/4 inch hex shank?
12 replies so far
View johnstoneb's profile
johnstoneb
3161 posts in 3090 days
#1 posted 02-21-2019 05:16 PM
Do a search for hex shank drill bits.
-- Bruce, Boise, ID
View WayneC's profile
WayneC
14359 posts in 5014 days
#2 posted 02-21-2019 05:34 PM
View SMP's profile
SMP
2880 posts in 823 days
#3 posted 02-21-2019 05:59 PM
I’ve never seen a 1/32. I have purchased several kits that come with 2×1/16 bits, and I snap them like crazy, I first wondered why the kits came with 2, but 2 is not enough,lol. I am guessing most manufacturers don’t make them in 1/32 since they would probably snap just looking at them. I think that hex shank leverages against or something. Because I don’t break regular bits, just the hex ones.
WayneC
#4 posted 02-21-2019 06:05 PM
For something like this, you could also consider a hand drill….
View Bill Berklich's profile
Bill Berklich
1175 posts in 1305 days
#5 posted 02-21-2019 06:21 PM
For a 1/32” bit I usually use a pin vise and do it by hand. If you buy/use the chuck WayneC linked be sure you buy a half dozen drill bits. they’ll snap lie icicles.
Here… https://www.thesprucecrafts.com/use-pin-vice-mini-twist-drill-2366898
-- Bill - Rochester MI
WayneC
#6 posted 02-21-2019 06:39 PM
I’m in agreement Bill. By hand drill, I was thinking on old egg beater style hand drill like a millers falls #2.
View SMP's profile
SMP
#7 posted 02-21-2019 06:40 PM
For a 1/32” bit I usually use a pin vise and do it by hand. If you buy/use the chuck WayneC linked be sure you buy a half dozen drill bits. they ll snap lie icicles.
- Bill Berklich
I was looking for the Harbor Freight pin vise I have. I can’t seem to find on their site, but it was cheap. Maybe they have in stores but not online. Amazon carries some too, but many are in mm, so you would be looking for .8 mm.
View Andybb's profile
Andybb
2941 posts in 1521 days
#8 posted 02-21-2019 07:00 PM
A 1/32” bit is a mighty fragile piece of metal. Get more than one.
-- Andy - Seattle USA
View wingless's profile
wingless
79 posts in 659 days
#9 posted 02-21-2019 07:21 PM
The Dremel 628-01 kit includes a 1/32” drill (no hex shank) that I use in my Dremel or in a pin vise.
View WoodenDreams's profile
WoodenDreams
1182 posts in 828 days
#10 posted 02-21-2019 10:22 PM
I get most of my bits through Menards. they carry the Masterforce brand with the 1/4” hex shaft like this one . https://www.menards.com/main/tools-hardware/power-tool-accessories/drill-bits-accessories/masterforce-reg-black-oxide-twist-drill-bit/2523900/p-1444444249694-c-10079.htm?tid=8215151377959047842&ipos=6 they also carry assortment size multipacks in the 1/4” hex shank.
wingless
#11 posted 02-21-2019 10:48 PM
- WoodenDreams
Nice link.
The 1/32” size requested by the OP was not located.
Please provide a link if possible.
View CaptainKlutz's profile
CaptainKlutz
3835 posts in 2411 days
#12 posted 02-22-2019 06:51 AM
+1 Any 1/32” drill bit is going to be very fragile. Buy extra!
None of the 1/4 shank hand tools will be accurate enough to prevent breaking bits that small.
Just checked both MSCDirect and McMaster, neither one show 1/32 available in hex shank? If they don’t have it, will be almost impossible to find.
Suggest using a pin vise and regular drill bit if drilling by hand. You will still break bits, but less often.
Can find tons of them cheap on Amazon. Hobby Lobby also sells a set with drill bits. Even Harbor Freight carries one, but they call it something strange – forget what now – Just ask store clerk.
FWIW – If you have trouble finding fractional drill bits that small, look for alternate sizes. A number 68 bit is 0.031, only 0.00025” smaller. Also a metric 0.8mm bit is only 0.00024” larger. If you are drilling wood, that difference won’t even be noticed. When using small diameter drill bits, number drills are most often used by machinst.
Best Luck.
