Gaps in table top
« back to Joinery forum
Forum topic by brotherriver posted 02-20-2019 03:49 PM 361 views 0 times favorited 7 replies Add to Favorites Watch
View brotherriver's profile
brotherriver
3 posts in 28 days
02-20-2019 03:49 PM
Hi all,
Beginner woodworker, this is my first time posting here. I’m in the process of building a maple top table with steel legs and I’ve been having trouble getting clean glue lines. I’ve tried adjusting the outfeed table using a ruler and it seems to be sitting at the right height, but the gaps persist. Any help will be appreciated.
7 replies so far
View ChefHDAN's profile
ChefHDAN
1328 posts in 3147 days
#1 posted 02-20-2019 04:06 PM
Outfeed table on what tool? Are you using a jointer?
Sometimes the jointer fence can be the slightest bit out of true, if you joint the top face of the board on the right against the fence and then the bottom face of the board on the left against the fence, you can cancel out any slight variations.
View Firewood's profile
Firewood
670 posts in 1932 days
#2 posted 02-20-2019 04:56 PM
Assuming you are referring to the jointer, double check the height of the knives in relation to the outfeed table. When you place a small scrap piece on the outfeed table and over the knife, it should only advance about 1/8” or so when manually rotating the cutter head. Also, you mentioned you checked the outfeed table with a ruler – make sure the infeed and outfeed tables are coplaner their full length. Hope this helps.
-- Mike - Waukesha, WI
View SMP's profile (online now)
SMP
456 posts in 203 days
#3 posted 02-20-2019 05:16 PM
- Firewood
Wanted to highlight this here. On mine, checking with a short ruler was fine, but once I layed a straightedge(4’ drywall square) that went the whole way across the length, I noticed it had a belly. Both edges sagged just a tad. After adjusting it works much better. https://www.woodmagazine.com/tuning-up-your-jointer
View bondogaposis's profile
bondogaposis
5255 posts in 2649 days
#4 posted 02-20-2019 06:22 PM
Dry clamp the top together and see if the gaps close. If they do, then just glue it up.
-- Bondo Gaposis
brotherriver
3 posts in 28 days
#5 posted 02-20-2019 09:09 PM
Yes, jointer, sorry. Thanks for the all advice, alternating between faces against the fence seems to have done the trick.
ChefHDAN
#6 posted 02-20-2019 10:46 PM
Well the good news is if that did the trick, then your fence is the culprit and needs to get to 90*
brotherriver
3 posts in 28 days
#7 posted 02-27-2019 04:48 PM
Jointer got a full tune up just to be sure everything was sitting how it’s supposed to be. Thanks again
