What Kind of tint to darken epoxy
Forum topic by ScottKaye posted 02-19-2019 09:08 PM 321 views 0 times favorited 8 replies Add to Favorites Watch
View ScottKaye's profile
ScottKaye
747 posts in 2280 days
02-19-2019 09:08 PM
Looking for a quick and easy tint or dye to mix in Epoxy that hopefully is locally available in the big box store. any suggestions? Trying to fill some defects in walnut and would like to tint/dye the epoxy.
Thanks
Scott!
-- "Nothing happens until you build it"
8 replies so far
View RobHannon's profile
RobHannon
253 posts in 857 days
#1 posted 02-19-2019 09:16 PM
You will probably find better options at a craft store. Dry pigments are compatible with just about everything. Acrylic paints work pretty well with most things I have tried, but mixing small batches is hard.
Sawdust and epoxy also works, better than sawdust and PVA in a lot of cases.
If you just want to go black and not colormatch, printer toner works. A little goes a long way and it can make a huge mess if a stray breeze comes through. I am not sure if toner will work with a fiberglass/polyester resin, though.
View SMP's profile
SMP
595 posts in 232 days
#2 posted 02-19-2019 09:16 PM
I used to be able to find this stuff at Home Depot when I built custom audio components, but my local HD no longer has it in stock, so I grab at a local boating store:
https://www.westmarine.com/buy/evercoat--resin-coloring-agent--P004_120_004_002
View Julian's profile
Julian
1463 posts in 3017 days
#3 posted 02-19-2019 09:17 PM
I have used india ink. You can get it in many colors at Hobby Lobby or Michaels.
-- Julian
View AandCstyle's profile
AandCstyle
3202 posts in 2584 days
#4 posted 02-19-2019 09:25 PM
Scott, char a piece of scrap with a propane torch and scrape the black off the surface into a small plastic cup, add the epoxy and stir assuming you want black.
-- Art
ScottKaye
#5 posted 02-19-2019 09:26 PM
Thanks guys. You all gave me a few good ideas
View Jim Finn's profile
Jim Finn
2692 posts in 3249 days
#6 posted 02-19-2019 10:49 PM
I have tinted epoxy with ground up chalk. Yes, blackboard chalk ( or sidewalk chalk)
-- No PHD just a DD214
View MrUnix's profile
MrUnix
7301 posts in 2526 days
#7 posted 02-19-2019 10:57 PM
There is an almost endless amount of stuff you can tint epoxy with, and some things you would never think of work amazingly well (like used coffee grinds for nice deep dark brown). Generally, just stay away from anything that is water based and you should be good. Liquid (paints and inks), stone (powered, crushed, ground), sawdust, metal filings/shavings, various powders (dry pigments, chalk, dry coloring agents, etc…), the list goes on and on… and when in doubt, test a small amount to make sure it will work.
View JayT's profile
JayT
6131 posts in 2538 days
#8 posted 02-19-2019 11:51 PM
I use Testor model paint. Readily available, wide variety of colors and inexpensive. A couple drops are enough to tint a pretty decent batch of epoxy.
-- In theory, there is no difference between theory and practice. In practice, there is.
