Mortising machine
Forum topic by MrRon posted 02-17-2019 05:48 PM 522 views 0 times favorited 8 replies Add to Favorites Watch
View MrRon's profile
MrRon
5364 posts in 3541 days
02-17-2019 05:48 PM
I have a HF mortising machine that I bought several years ago and haven’t used much. I put it to work yesterday cutting 1/2” mortises in common pine for legs for a tool stand I’m building. Before cutting, I sharpened the bit and chisel with a diamond hone. They were both sharp. The mortises went well, but they were pretty ragged, requiring a clean up with hand chisels. As a result,the mortises vary in width by a few thousands. I now want to cut the tenons, but I want to cut them all the same thickness. That means some joints will be tight and others may be loose. What would you suggest I do to make sure the structure is sturdy? Will glue alone make the loose joint secure, or should I “tailor” each tenon to each mortise? I’m thinking to make all the tenons slightly oversize and custom fit each joint, by sanding and filing. The stand I am building is for a scroll saw I just bought.
8 replies so far
View waho6o9's profile (online now)
waho6o9
8593 posts in 2875 days
#1 posted 02-17-2019 06:38 PM
I would custom fit each tenon to their respective mortise.
View LesB's profile
LesB
2004 posts in 3741 days
#2 posted 02-17-2019 06:45 PM
If the joints are only very slightly loose you could use polyurethane glue which expands as it cures and will fill small gaps. Putting the glue on the tenon and Spritzing water in the mortise of the joint will speed up the curing process. Be sure to clamp the joint because the expanding glue can also force the joint apart if it is not clamped.
That said, the expanded glue is not as strong as a tight joint but for the stand you are building it should work fine.
-- Les B, Oregon
View Andre's profile
Andre
2499 posts in 2104 days
#3 posted 02-17-2019 07:49 PM
- waho6o9
I cut them all to the biggest size on the table saw then fit each one to mate with a 60 1/2 LN Rabbet plane!
View bondogaposis's profile
bondogaposis
5255 posts in 2649 days
#4 posted 02-17-2019 08:00 PM
Cut the tenons oversize, then sneak up on the fit of each one using a shoulder plane.
-- Bondo Gaposis
View ScottKaye's profile
ScottKaye
745 posts in 2251 days
#5 posted 02-17-2019 09:13 PM
And if the mortises end up over sized as compared to the tenon, glue some thin veneer to the cheeks of the tenon and try again. Preferably your off cuts from the tenon cheeks.
-- "Nothing happens until you build it"
MrRon
#6 posted 02-18-2019 09:16 PM
Thank you all. You have confirmed what I thought would be the best solution and custom fit each tenon.
View Andybb's profile
Andybb
1797 posts in 901 days
#7 posted 02-18-2019 09:28 PM
Yes. Custom fit by either shaving or shimming. (Should be obvious but make sure to glue both sides of the shim.) My preference would be to shave a fatty than shim a skinny one.
-- Andy - Seattle USA
View moke's profile
moke
1339 posts in 3074 days
#8 posted 02-18-2019 09:35 PM
Like Bondo, I have always cut the slightly oversize and snuck up on them with a shoulder plane. I have a friend that if he got them slightly oversize, shimmed them with playing cards…..I have eaten at the table he did that to, and it is rock solid…..(I was trying to give him grief while wiggling it)
-- Mike
