MM 16 Bandsaw Upgrade
Forum topic by langski93 posted 02-15-2019 03:21 AM 290 views 0 times favorited 2 replies Add to Favorites Watch
View langski93's profile
langski93
118 posts in 3730 days
02-15-2019 03:21 AM
Topic tags/keywords: bandsaw mm16
After a couple years of using my MM16 bandsaw, I finally got tired of dealing with the cracked (it arrived that way) dished and unalignable table insert. A great piece of equipment that some genius (bean counter) decided to save a few bucks on a seemingly unimportant part (until it ain’t). The plastic insert was replaced by a sturdy aluminium plate that was dimensioned from the original. If anyone would like to source one of these PM me and I will give you the contact info. Cheers.
-- Langski, New Hampshire
2 replies so far
View splintergroup's profile
splintergroup
2573 posts in 1520 days
#1 posted 02-15-2019 09:48 PM
Thanks for the pics Langski, I read your post on the MM user group and my interest was piqued 8^)
For my use, I’d like a replacement insert that acted as a platform for more common inserts and materials.
The large rectangular hole in the MM16 table would have a filler piece like your photo shows, except the blade slot would be a rectangular section, maybe 1” wide by 1-3/4” long. This inner section would be a shelf, 1/4” below the table surface such that shop made 1×1-3/4” inserts would be easily cut, installed, and tossed when they wear out.
Often I’m needing a zero clearance insert for some cut, then a deeper insert when I run a wide blade. The ability to easily make and replace inserts is what would be key.
View TungOil's profile
TungOil
1143 posts in 792 days
#2 posted 02-16-2019 02:33 AM
I agree, that table insert on the MM16 is just abysmal. Please PM you source to me. Thanks!
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
