Single Rabbets on 3/4 Birch Ply
« back to Joinery forum
Forum topic by JP4LSU posted 02-12-2019 11:01 PM 574 views 0 times favorited 6 replies Add to Favorites Watch
View JP4LSU's profile
JP4LSU
109 posts in 925 days
02-12-2019 11:01 PM
Topic tags/keywords: question jig router
Hey guys, I’m going to be making a router cabinet for my Veritas Router Table Top I picked up on CL.
I have 3/4 Birch Ply and was planing on using a single rabbet joint to join the sides to the back and I will Dado a middle shelf and the bottom to the sides.
So the rabbets will be in the side panels.
Being plywood I don’t see a reason to use a rabbetting bit since there are no bearings that will match up with the 3/4 ply thickness of the back panel. (At least I don’t think there are bearings out there for ply rabbets)
My plan was to set up a guide and just use a straight bit. I could have the base of the router ride against the guide or have a bearing on the bit and ride against a guide at the edge of the cut.
What do you guys think or what do you do? I’m worried about creating inconsistencies in each panel I cut, if Im setting up a guide each time.
Keep in mind…..I don’t have a table saw. Yes I know, I’m going to have a router table before a table saw. Flog me now as you wish. LOL!
I actually have no room until I get one garage cleaned up so I can move some stuff out of my little shop to the garage. Plus I have a metal lathe that is taking up space too. But that ain’t going nowhere.
Actually typing this is making me think through this a little more.
Idea: What if I use a standard rabbet bit that will make the rabbet a tad deeper than the plywood thickness. Then I flush cut the long part of the rabbet sticking out after I assemble?
Alright, enough rambling and I’ll let the pros have a word.
Thanks Gents,
JP
View Bill_Steele's profile
Bill_Steele
708 posts in 2509 days
#1 posted 02-14-2019 07:49 PM
I think if you have a rabbeting bit with interchangeable bearings—like this—then use that in your handheld router to sneak up on the final depth of the rabbet. I feel that this approach will be slightly better than clamping a guide to the stock and using a straight bit. I have no doubt that a clamped straight edge can yield very accurate results—I just think that there is more opportunity for error in that approach.
I would definitely cut the rabbet a little wide and trim it flush to the back with a block plane or a flush trim router bit. I think it is much easier to get a flush fit this way—rather than trying to make the rabbet exactly the right width.
Once you build your router table and fence you can cut the rabbets on the router table.
View JRsgarage's profile
JRsgarage
367 posts in 1287 days
#2 posted 02-14-2019 08:25 PM
Do you have an edge guide for your router? I usually use straight bit and an edge guide for similar cuts
-- “Facts don't care about your feelings.” ..., Ben Shapiro
View Rayne's profile
Rayne
1312 posts in 2317 days
#3 posted 02-15-2019 01:00 AM
- JRsgarage
That won’t work on a rabbet. It would work great for a dado though.
View bandit571's profile
bandit571
25925 posts in 3461 days
#4 posted 02-15-2019 01:14 AM
Have used a Stanley No. 78 rebate plane for rebates in plywood, before.
JP4LSU
#5 posted 02-15-2019 02:29 AM
Thanks for the reply and input Bill.
I discovered that Eagle America has a rabbit bit with an 11/16 bearing. So I ordered the bit and their entire bearing set for $80.  I’m with you on setting a guide up, it’s an opportunity to have variations.
JRsgarage, I totally forgot when I bought this Hitachi M12V used it came with an edge guide. Now if I had plywood size straight bits. Ha!
I guess I could use a normal straight bit and make 2 passes using the edge guide.
Thanks gentlemen
JRsgarage
#6 posted 02-15-2019 05:22 PM
- JRsgarage
That won t work on a rabbet. It would work great for a dado though.
- Rayne
Maybe not the traditional way but definitely works well for me, especially on small plywood panels. Keeps me from setting up the dado and fence on TS. Just adjust the bit from fence on guide to cut on edge.
