Downdraft Table
Forum topic by myxology posted 02-11-2019 04:31 PM 338 views 0 times favorited 5 replies Add to Favorites Watch
View myxology's profile
myxology
73 posts in 1511 days
02-11-2019 04:31 PM
I’m curious how many of you have incorporated self-made downdraft tables in your works shop. Do you like them? Do you USE them? Please feel free to share photos. I see most of them are made with pegboard and that was what I was considering. Looking forward to your feedback.
-- Is this thing plugged in?
5 replies so far
View pottz's profile
pottz
4104 posts in 1255 days
#1 posted 02-11-2019 07:23 PM
i made a small one a few years ago using the panels from rockller,which has much larger holes and rubber rings to keep work pieces from sliding around.i only used it a few times and didnt really think it did much for collecting dust and dismantled it.i now have my sanders hooked up to a vac system.
View Davevand's profile
Davevand
93 posts in 1107 days
#2 posted 02-11-2019 07:46 PM
I made one, 30×24x6 using pegboard. It didn’t work so well until I enlarged a lot of the holes to 3/8 inch. I am now considering enlarging the holes where I do most of my work to 1/2 inch. I also added side shields to it. It works good for sanding and OK for hand routing, I think the larger holes will help even more.
View t3steve's profile
t3steve
9 posts in 160 days
#3 posted 02-11-2019 08:44 PM
I like the looks of this one, but I haven’t built one yet.
View tomsteve's profile
tomsteve
907 posts in 1490 days
#4 posted 02-12-2019 04:42 PM
dont have camera access but heres a video i used to build mine
https://www.youtube.com/watch?v=V9USUzLaMrI&t=382s
he did a lot of routing for the runs- i just ripped some 3/4 strips, nailed in place to the top for the grid, then screwed the bottom on.
mine is in the middle of an 8 foot bench top and it rocks. io use it every time im sanding.
myxology
#5 posted 02-14-2019 09:53 PM
tomsteve, I like the way you think. This solution looks like it would be more effective than the standard box with a pegboard solution. Thanks for linking that!
