3'' Gummed Veneer Tape Were To Buy?
Forum topic by rustynails posted 02-11-2019 01:54 AM 253 views 0 times favorited 6 replies Add to Favorites Watch
View rustynails's profile
rustynails
817 posts in 2799 days
02-11-2019 01:54 AM
I am looking for some wide water activated gummed veneer tape to use in veneering projects. I looked on the web but could only fine the standard 3/4’’ that I use and have. Anyone know of a good source or could recommend?
Thanks
View shipwright's profile
shipwright
8220 posts in 3068 days
#1 posted 02-11-2019 03:36 AM
What are you using it for?
rustynails
#2 posted 02-11-2019 10:20 AM
To cover the back of veneer panels that have multiple pieces to keep them intact. Also to be used to stabilize veneer when cutting fragile stock.
Or something wider than 3/4’’.
shipwright
#3 posted 02-11-2019 03:25 PM
I thought it might be for reinforcement. It is a lot more expensive than newspaper and HHG and I find that when I use it to save a bit of time it doesn’t work as well either.
Lots of people use masking tape for assembly although I prefer mounting boards with french kraft paper.
You’ve been to ASFM, right?
To actually answer your question, I bought some ~2” I think from Paul Schurch’s website years ago. I don’t use it much though for the above reason.
rustynails
#4 posted 02-11-2019 11:51 PM
Paul thanks for the lead. As far as the hide glue with paper yes that works well but to heat the glue and such can be a time problem and to set up the glue pot in not something I like to do for different things. Masking tape works well for a lot of things but when cutting it is harder to cut and if you leave tape on to long it has a tendency to not come off and damage the veneer, especially in the thinner fragile veneers. Also I am not wanting it for assembly but more for stabilizing burls and such.
I know that Paul Schurch’s has shut down his site and not selling product like he used to.
shipwright
#5 posted 02-12-2019 05:44 AM
I agree. I would never use masking tape for reinforcing for cutting. It’s easy for me as I have HHG on all day every day in the shop. It only takes a few minutes and it stays put better than veneer tape.
View Richard's profile
Richard
11077 posts in 3303 days
#6 posted 02-13-2019 05:44 AM
- shipwright
I agree!
Rich
-- Richard (Aurora, Ontario, CANADA)
