Forum topic by corelz125 | posted 02-10-2019 08:52 PM | 612 views | 0 times favorited | 10 replies | ![]() |
Came across this article today. Having seen many cross cut sled posts maybe this will help some out. |
10 replies so far
#1 posted 02-13-2019 03:49 PM |
This kinda depends on how far you want to go with your crosscut sled. Are you trying to reinvent the wheel, or do you just want something that works simply and reliably? In my own experience, the “Keep It Simple, Stupid” method works best. My own crosscut sled is made of scrap 1 X screwed to a 1/2” plywood base sliding on maple runners. It is basically a box without ends sized to fit the saw table. Many here at LJ would look down their noses at such a simple, POS “pile of lumber” as they would say. But here’s one of the projects I’ve made using it:
#2 posted 02-13-2019 11:25 PM |
You have a pic of it olegrump? |
#3 posted 02-14-2019 07:24 PM |
I tend to agree with the old grumpy one—no need for a fancy crosscut sled—but if you’re going to spend the time making one—you might as well do it right and make it accurate. A crosscut sled is something you may use on almost every project and you could use it for many years—for me that sorta justifies any added expense or effort. I have several crosscut sleds—none as fancy as the one from the link—but I do like the one in the link. I tend to use aluminium angle iron for my fence. I have one sled where the fence is at the front of the sled (rather than the back)—this allows me to crosscut wider panels. |
#4 posted 02-14-2019 10:26 PM |
I use my sled on just about everything I build. I have been looking at the Incra 5000 Sled. Not cheap but very nice. We’ll see how that goes. -- I always knew I would grow old, But I expected it to take longer! |
#5 posted 02-15-2019 01:30 AM |
Absolutely a cross cut sled gets tons of use. Probably one of the most used jigs in the shop. The sleds are kind of like cars the one in the link is like the rolls Royce of sleds but toyota yaris (2 pieces of lumber and sheet of plywood) get you to the same place. |
#6 posted 02-15-2019 07:53 PM |
The weather cooperated enough so I could take the sled outside and get some pix to post. Again, bare bones approach, but works quite well for me: And my basic stop block for repeat cuts and hold down device By no means elegant, but quite effective. I screwed the runners to the base, ran it aboout 2/3 of the way through the table saw, used a framing square to mark lines at a 90 degree angle to the kerf, so the fences would be positioned correctly, glued and screwed on the front and rear fences, raised the blade to cut through 1 1/2 inch stock and sawed through the whole contraption. Some sleds I’ve seen have quite elegantly shaped tops on the rear fence. They look GREAT, but I left mine flat across the tops so I could clamp any mannner and number of stops and hold downs inside the box. This all being said, the main thing to remember is that it is YOUR shop and YOUR sled. If you have desire to build a fancy version, by all means do so. Just know that a “Swiss Army Cross-Cut Sled” isn’t absolutely necessary to make things. -- OleGrump |
#7 posted 02-15-2019 08:34 PM |
Note the last line in “sources” where it says this article is a reprint. “This story originally appeared in American Woodworker May 2007, issue #128.” Probably doesn’t mean much if you really like this particular sled, because end of the day, this is most important. It’s just that since then a whole lot has changed in the way sleds are made, and look. I think the biggest take away from what has been learned is that fences made with a good grade of plywood, or even MDF are a lot more stable than a 2×6 from the BORG. Having a fence made to be a right angle to the saw blade, and then staying that way are a number one consideration for a good sled. -- Think safe, be safe |
#8 posted 02-15-2019 08:49 PM |
I miss American woodworker. At least their content didn’t disappear. -- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list. |
#9 posted 02-15-2019 09:41 PM |
Yeah Pop WWing offers DVDs and thumb drives of all the old stuff, plus Woodwork. I always liked the B$W no advertising of it. -- Think safe, be safe |
#10 posted 02-15-2019 10:27 PM |
Simple and effective old grump. SteveN some of the reprint articles pop up at the right time sometimes. |
Forum | Topics |
Woodworking Skill Share
12393 |
Woodturning
2368 |
Woodcarving
476 |
Scrollsawing
364 |
Joinery
1536 |
Finishing
5364 |
7086 |
29561 |
CNC Woodworking
247 |
Hand Tools
5758 |
Jigs & Fixtures
1509 |
Wood & Lumber
6612 |
1464 |
Focus on the Workspace
2299 |
1209 |
Woodworking Trade & Swap
4951 |
LumberJocks.com Site Feedback
2263 |
Coffee Lounge
9124 |
