Removing paper template applied with spray adhesive on small parts?
Forum topic by jamsomito posted 02-10-2019 03:49 PM 698 views 0 times favorited 11 replies Add to Favorites Watch
View jamsomito's profile
jamsomito
415 posts in 697 days
02-10-2019 03:49 PM
Hey all, last time I tried this the parts were much bigger and I just sanded the paper off. The adhesive underneath really gummed up the sandpaper though (3M 45 general purpose). These parts are too small for a ROS this time, so I feel like removing with a solvent will be better anyway. Can I just soak in mineral spirits or acetone and peel it off? The can says acetone clean up, but I don’t know about when cured.
11 replies so far
View Knockonit's profile
Knockonit
521 posts in 473 days
#1 posted 02-10-2019 04:04 PM
i typically use a damp rag, let it soak a bit, hit again, then peel off
jamsomito
#2 posted 02-10-2019 04:10 PM
Water?
View JRsgarage's profile
JRsgarage
352 posts in 780 days
#3 posted 02-10-2019 04:14 PM
I use a heat gun and pass over it few times…peels off easily
-- Two is One, One is None
View Planeman40's profile
Planeman40
1351 posts in 3031 days
#4 posted 02-10-2019 04:20 PM
I use paper patterns attached to wood (and other materials) frequently. I find acetone and alcohol are usually the best removers. I just paint some over the top of the paper glued on patterns, let it soak through, then peel the pattern off. Any adhesive residue can be easily scraped off with a razor blade. I do the same with removing labels from glass jars. Some labels are really stuck on. For these I use paint brush cleaner which removes almost anything!
View MrRon's profile
MrRon
5364 posts in 3514 days
#5 posted 02-10-2019 05:24 PM
I’ve watched several videos of scroll saw projects where a paper pattern was attached with a spray adhesive. After finishing the cuts, they used a heat gun to remove the pattern. To remove any adhesive residue remaining, you could use a product called “goo gone”. I use it and it removes the residue quickly and easily. It will also remove those nasty bumper stickers.
View MrUnix's profile
MrUnix
7186 posts in 2469 days
#6 posted 02-10-2019 07:52 PM
Easy peasy… wipe down the remaining templates with mineral spirits (get them good and saturated). Wait a few minutes for it to work, and then they will almost fall off by themselves. Clean any remaining residue with mineral spirits on a rag. Works great on both 3M 45 and 77. Apparently, as stated by planeman40 above, acetone or alcohol will work as well, although I’ve never tried it – I always have MS on hand, so it’s my go-to solvent.
View Redoak49's profile
Redoak49
3805 posts in 2259 days
#7 posted 02-10-2019 09:39 PM
For scroll saw patterns, I put down blue masking tape and then attach the pattern with 3M77.
View Tony1212's profile
Tony1212
286 posts in 2005 days
#8 posted 02-11-2019 03:10 PM
I made a video of transferring images using waterbased poly. I just used some water to rub the paper off.
-- Tony, SW Chicago Suburbs
View htl's profile
htl
4468 posts in 1430 days
#9 posted 02-11-2019 09:24 PM
For my model parts some times I use blue tape like Redoak said but always use Elmore Glue Sticks, no sticky spray mess to deal with..
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View Steve's profile
Steve
970 posts in 853 days
#10 posted 02-12-2019 02:36 AM
Heat gun always works for for me with 3m77 adhesive
View Lazyman's profile
Lazyman
2874 posts in 1658 days
#11 posted 02-12-2019 02:54 AM
+1 on the glue sticks for attaching templates. I hate spray adhesive.
