Tenon saw, or frame/bow saw?
« back to Hand Tools forum
Forum topic by Tony Ennis posted 02-09-2019 10:32 PM 890 views 0 times favorited 9 replies Add to Favorites Watch
View Tony Ennis's profile
Tony Ennis
139 posts in 4151 days
02-09-2019 10:32 PM
I would like a tenon saw more appropriate to large joints than my little 22 tpi dovetail saw. Or, would a frame saw be a better choice?
I am making a bench with 3×5.5” legs and rails. I want to be able to comfortably cut tenons in those pieces.
As always, I am looking for bank-for-the-buck, honest user tools, not showpieces.
-- Tony
9 replies so far
View BFamous's profile
BFamous
344 posts in 1135 days
#1 posted 02-09-2019 10:37 PM
If you want bang for your buck, why buy a new tool? Why not just cut then tenons in the table saw and call it a day?
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
Smitty_Cabinetshop
17241 posts in 3633 days
#2 posted 02-09-2019 10:41 PM
Tenon saw, or even a mitrebox saw, would be a reasonable addition to the saw till. More control on tenon cuts vs. bowsaw, IMO.
-- Don't anthropomorphize your handplanes. They hate it when you do that. - OldTools Archive -
View theoldfart's profile
theoldfart
12467 posts in 3466 days
#3 posted 02-09-2019 11:45 PM
Big tenon saw but Smitty’s right on with the mitre box saw.
Start with the tenon for better control
Finish with the mitre saw
Clean the waste with a big mortis chisel.
The legs were 6×6 DF milled to approximately 5×5
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View SMP's profile
SMP
3460 posts in 920 days
#4 posted 02-13-2019 05:23 PM
Frame saw would be more appropriate than bow, tenon would be first choice, or you could crosscut and chop out with a chisel.
View ed13's profile
ed13
32 posts in 1565 days
#5 posted 02-13-2019 08:28 PM
How big do you mean by “large joints?”
Tony Ennis
#6 posted 02-14-2019 04:05 AM
@ed13, cutting a tenon on a 3” x 5” bench leg, for example.
-- Tony
View ed13's profile
ed13
#7 posted 02-14-2019 03:38 PM
Tony, swayed by Tage Frid’s book, I bought a frame saw early on. I’m sure others can use them, but I find it awkward and unbalanced. Once it is placed on the line and in the cut I guess it is okay, but I just find I have much more control with a tenon saw. You won’t always be building stuff this size, so as long as the plate reaches deep enough, I’d cut the tenons with a tenon saw. I find a 14”, 12 tpi, with a fine set and filed rip does all my joinery, including dovetails and tenons. For the big tenons you need to do, I’d bet you could do them with a handsaw or panel saw and then clean up with chisel and router plane. You’ll need that cleanup anyway. If the wood is straight grained, like oak, you don’t even need to saw the tenons. Cross cut the shoulders and then split the tenons. There are tricks for splitting so that you read the grain as you go to watch for the cut diving past your line. Lots of options.
View OleGrump's profile
OleGrump
579 posts in 1359 days
#8 posted 02-15-2019 11:17 PM
Getting correct tension on a frame saw is sometimes (or usually?) tricky, and as you have to release the tension after each use, there is no ‘set it and forget it” with them. It seems the narrower the blade, the more trouble one has keeping them heading in the desired direction. They are pretty neat when they work, though.
-- OleGrump
Tony Ennis
#9 posted 02-16-2019 06:00 PM
ok, upon reading the opinions above, a tenon saw sounds like a good choice.
God help us all, but do we have preferred brands and models?
-- Tony
