Forum topic by paul23 | posted 02-09-2019 01:05 AM | 574 views | 0 times favorited | 2 replies | ![]() |
I never noticed that my Poitras R-arm saw was out of adjustment until I bought Freud’s 90 tooth cross-cut blade. It cuts beautifully, except that the first inch or two burns in hardwood. I discovered that the blade is dog-tracking a wee bit. The manual doesn’t describe adjustments much more than to say everything is factory set and should be good forever. I think the adjustment is made with two small set-screws that turn with a small allen wrench. Both screws will loosen, but neither will tighten, even when the other is loose. I can feel that forcing them will likely cause my little allen wrench to snap, and these screws are about an inch inside the casting (I’d never get the broken piece out again). Any advice will be appreciated (unless it starts something like, “I’ve never seen such a saw before, but . . . .) |
