How would you joint this chair?
Forum topic by SeanD posted 02-09-2019 01:05 AM 473 views 0 times favorited 7 replies Add to Favorites Watch
View SeanD's profile
SeanD
1 post in 256 days
02-09-2019 01:05 AM
It looks like the pieces are dadoed together and bolted. I guess maybe to be able to disassemble? It seems like there might be a better way…
7 replies so far
View LesB's profile
LesB
2206 posts in 3957 days
#1 posted 02-09-2019 01:39 AM
I can think of other ways but not necessarily better.
Through mortise and tenon type joint where the seat and back have tenons that fit into through dados on the sides.
Cleats on the fastened to the sides and the seat and back fastened to the cleats.
Some type of over lapping and interlocking joints between the back, seat, and the sides. I use this method on a knock down child’s rocking chair where everything interlocked and was held with a locking wedge.
Blind dovetails that the seat and back slide into….won’t work well on plywood.
-- Les B, Oregon
View WoodenDreams's profile
WoodenDreams
752 posts in 425 days
#2 posted 02-09-2019 05:21 AM
Simple as it may be, the back is to help prevent side to side sway. And the sides are one piece legs to prevent back and forth sway. You could add additional support to the back with screws in the sides attaching the back. drill a pilot hole first to prevent splitting of the wood. Some foot stools are designed this way also.
View ChefHDAN's profile
ChefHDAN
1461 posts in 3363 days
#3 posted 02-09-2019 01:09 PM
Domino
View AlaskaGuy's profile
AlaskaGuy
5359 posts in 2823 days
#4 posted 02-09-2019 10:49 PM
Doesn’t show very well this whole project was made with T M&T. If you zoom in you can see the tenons coming thru he side of the end.
View builtinbkyn's profile
builtinbkyn
2942 posts in 1454 days
#5 posted 02-09-2019 11:09 PM
There’s something odd about this pic. Looks like it was edited. The bottom of the legs don’t match the construction. Hope that makes sense. Anyway, the thru mortise seems like the nicest idea. Otherwise cleats under the seat are another way to go. Simply screwed together as shown doesn’t appear to be the best method IMO.
-- Bill, Yo!......in Brooklyn & Steel City :)
View ArtMann's profile
ArtMann
1436 posts in 1330 days
#6 posted 02-09-2019 11:59 PM
It looks like the cuts that are circled may have been routed to allow for stacking multiple chairs.
View PurpLev's profile
PurpLev
8551 posts in 4162 days
#7 posted 02-10-2019 12:00 AM
from experience with similar type of items they are rarely dadoed – these are usually aligned with alignment dowels, and pulled together with bolts.
not saying that’s the best way to joint this, but this is the cheapest and easiest to mass produce these parts. also makes it easy to break down and sell in smaller boxes (logistics)
