Forum topic by jamsomito | posted 02-06-2019 01:52 PM | 1015 views | 0 times favorited | 32 replies | ![]() |
Saw the thread about removing dust after sanding between coats. Good stuff. My blue shop towels are failing me. I’m trying to build up a finish with Arm-R-Seal and the nubs are killing me. I eventually gave up and just put coat over coat (3 coats) thinking I would just sand before last coat, but the nubs are multiplying. At first I thought it was from dust in the room (inside basement bathroom) so I thoroughly cleaned everything but still more nubs. I looked while the finish was wet and theres fuzzies from my blue shop towels in it! So… What do you use to apply wipe-on poly? |
32 replies so far
#1 posted 02-06-2019 02:25 PM |
Old tee shirt works great. -- Sawdust Maker |
#2 posted 02-06-2019 02:38 PM |
Yep, old tee shirts. 100% cotton ones that have been washed to death :-) Take your cloth and whack it against your hand a few times or hit it with some compressed air. If you see any fibers floating around afterwards, don’t use that one. -- Kenny, SW VA, Go Hokies!!! |
#3 posted 02-06-2019 02:48 PM |
Cool, I’ll give it a shot. Is it still KonMari if the old t-shirts go to the shop?? |
#4 posted 02-06-2019 02:58 PM |
old t-shirts for wipe on, but have found it’s easier and faster to use the small HF HVLP spray gun, I can get 3 coats done in a couple of hours depending on weather conditions. -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#5 posted 02-06-2019 03:39 PM |
Been know to use coffee filters once or twice. They’re good enough to drink from they’re good enough to apply poly. Have you tried to keep the shop towels in a cleaner area before hand? |
#6 posted 02-06-2019 03:42 PM |
No, there’s a little dust on them, but I blow them off before using. But the problem is definitely micro-shreds and fuzzies, not dust from them. |
#7 posted 02-06-2019 03:52 PM |
I have no idea. I had to google KonMari to even know what it is ;-) -- Kenny, SW VA, Go Hokies!!! |
#8 posted 02-06-2019 03:54 PM |
Hahahaha, it’s a big thing these days. Just a joke. |
#9 posted 02-06-2019 04:20 PM |
Yep just have to thank it before throwing it away. |
#10 posted 02-06-2019 04:30 PM |
I usually buy a bulk pack of tees in the fall. After a year of wearing and washing, they move on to the shop. Free Tees from wherever, usually take a lot less time to get to the shop, cut out the screen printed area and the rest is good to use. -- Sawdust Maker |
#11 posted 02-06-2019 04:34 PM |
I use the white poly pads for this…they also are a mild abrasive so you get some help there too. https://www.amazon.com/gp/product/B000H5AG84/ref=ppx_yo_dt_b_asin_title_o06__o00_s00?ie=UTF8&psc=1 |
#12 posted 02-06-2019 04:51 PM |
100% cotton tee shirt rags… 100% clean and dust free before starting! -- Pete -- Bark less, Wag more, and SHOW COMPASSION to everyone you meet. |
#13 posted 02-06-2019 06:06 PM |
A good quality foam brush works with Arm-R-Seal very nicely. Lays down smooth and even. I used one to put the Arm-R-Seal on this mesquite table. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#14 posted 02-06-2019 06:13 PM |
Thanks for commenting on that. I was curious about the foam brushes but I’ve never used them before. One concern I have is these are small pieces with not much flat surface (proud finger joint boxes with relief details on top and bottom) so I didn’t know how that would work, but maybe it’s easier in practice than my mind. I think that’s contributing to my issues with the blue shop towels – small snags and whatnot. |
#15 posted 02-06-2019 06:18 PM |
I’ve never used Arm-R-Seal but I have tried applying poly with foam brushes and it did not go well. Air bubbles abounded. Maybe if it was cut a little thinner it would have gone better. I get such good results with wiping it on though that I really haven’t experimented with brushes and the wipe-on stuff. -- Kenny, SW VA, Go Hokies!!! |
Forum | Topics |
Woodworking Skill Share
12697 |
Woodturning
2572 |
Woodcarving
516 |
Scrollsawing
377 |
Joinery
1663 |
Finishing
5778 |
7383 |
30738 |
CNC Woodworking
268 |
Hand Tools
5986 |
Jigs & Fixtures
1624 |
Wood & Lumber
6839 |
1516 |
Focus on the Workspace
2415 |
1230 |
Woodworking Trade & Swap
5146 |
LumberJocks.com Site Feedback
2323 |
Coffee Lounge
9353 |
