Forum topic by ohtimberwolf | posted 02-04-2019 10:20 PM | 1638 views | 0 times favorited | 13 replies | ![]() |
Topic tags/keywords: flatten radial arm saw I think I have seen a post of something like this but I have never used one. larry Comments are welcome. -- Just a barn cat, now gone to cat heaven. |
13 replies so far
#1 posted 02-04-2019 11:19 PM |
no and i dont think i would ever attempt it.that bit would best be used in a large router on sled to flatten slabs.i only use my ras for 90 degree cuts.plus how would you mount it on a ras? -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#2 posted 02-04-2019 11:24 PM |
On my saw there is a place for a chuck to be used with router bits when turned with the shaft pointed down. -- Just a barn cat, now gone to cat heaven. |
#3 posted 02-04-2019 11:35 PM |
I use a bit very similar to that in my CNC router to precision flatten the work surface. I doubt if you would be very happy with the results with a chuck on the opposite end of a saw shaft. Those usually turn at around 3450 RPM, which is much too slow for that bit. It needs 10,000 RPM. There is also the element of danger spinning a bit like that in an application for which it was not designed. |
#4 posted 02-04-2019 11:57 PM |
if you do it please be extra careful IMHO i would not try it :<(((((((((((((((((( -- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<)) |
#5 posted 02-05-2019 12:42 AM |
Ok guys, I pay attention to those who know more than I. If I should order a tool such as this I will use it only in my ½” 3.5 hp router and build a sled for it. Thanks to all who have and will reply. I count on good advice. larry -- Just a barn cat, now gone to cat heaven. |
#6 posted 02-05-2019 01:01 AM |
I use a router sled and a Amana bit similar to this one, on a 2-1/4 Hp router. https://www.toolstoday.com/v-5312-45566.html Art man is right. RPM on a Radial arm saw is way to slow for this application. -- John |
#7 posted 02-05-2019 01:47 AM |
So thats a final score todate of 0 for yes, and 3 for no, with 1 fence sitter. Its a big sucker and have to say if you do use it in a hand held router ensure its constrained, its really suited for a shaper setup. Somewhere there is a recommendation advising when using router bits when its time to mount then due to their size. so Larry I personally do not want you meeting up with Morris too early. -- Regards Rob |
#8 posted 02-05-2019 01:58 AM |
Many…many years ago Craftsman made a circular planer that could be used on a radial arm saw with a drill chuck type mount on the opposite end of the motor from the saw blade shaft. It has three V shaped cutters mounted on a disk about 3” in diameter. I think I still have is somewhere in a back cupboard. It scared the heck out of me to use it. I will try to find it tomorrow to provide more info. I would not use that router bit on a radial arm saw but I guess if you made very shallow passes it might work….or it might damage the wood and the saw. Be sure to clamp the wood down tight if you decide to try it. -- Les B, Oregon |
#9 posted 02-05-2019 02:44 AM |
Thanks fellows but I think I will pass. I can’t risk losing any body parts at my age. larry -- Just a barn cat, now gone to cat heaven. |
#10 posted 02-05-2019 01:27 PM |
I think i still have one. Yeah scared me too, the blade guard sucked, and without the blade guard it scared me just looking at it. But the main thing is moving a large piece around to the surface that just a little 1” piece of MDF as the “fence” was scary, asking for kick back or kick side or kick angle |
#11 posted 02-05-2019 02:48 PM |
See my post #5 -- Just a barn cat, now gone to cat heaven. |
#12 posted 02-05-2019 03:10 PM |
See my post #5 Same with me, I just HAD to try my moulding cutter even though it looks like some rotating ninja weapon |
#13 posted 02-05-2019 03:13 PM |
SMP, what is your conclusion? larry -- Just a barn cat, now gone to cat heaven. |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
568 |
Scrollsawing
416 |
Joinery
1891 |
Finishing
6338 |
7903 |
32741 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1803 |
Wood & Lumber
7275 |
1631 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9655 |
