I've been hand planing for about 9 months now and occasionally when I have a relatively flat face on a board and the entire width of the bench plane is capable of cutting, the plane will continuously cut at both corners but not in the middle regardless of where I am on the board.
My setups are, new Lie-Nielsen #4 and #6 with original blades. The blades a recently sharpened and believe it or not, I have attempted Rob Cosman's and Matt Estlea's techniques to put a camber on the blades. I have the cap iron quite tight and the chip breaker is very close to the blade's edge (1/32nd or so).
I have a couple theories but wanted to ask someone with more experience. Perhaps the cap iron is too tight and is causing the blade to "cup" ever so slightly in the middle?
If there is no "relief angle", the blade will skate on the wood.
What is the iron bevel angle at the very tip of the blade (in the middle if not the same across the width)?
interesting reading (read also answers to comments).
I did check to see if my blade had a camber and it did not. Also, one error I believe I have made was in following the modified sharpening techniques of Rob Cosman when I took off my training wheels (Veritas MkII Honing Guide) and started sharpening freehand. Rob only uses 2 stones when resharpening his blades which already have a defined back, primary, and secondary bevel. I happen to have multiple sharpening stones and tend to touch my blades up using more than just two. In the sequence, I guess I found that as I move to a finer stone, I increase the secondary bevel ever so slightly. And as I resharpen, that secondary bevel gets larger and larger and larger. I've measured my secondary bevel to be about 35 degrees when I intended it to be closer to 25-28. My blade has just been skipping along the top of the workpiece. I'm in the process of flattening that secondary bevel back down to 25 degrees and will update once I've completed the resharpening. I'm also going to be sure that I get an actual (observable) camber on that blade. I've yet to buy a bench grinder so I'll make good use of my 320 grit sharpening stone. Thanks for the feedback.
Johnny7,
I hope it will solve the problem.
The hint is that if you start at the edge, the protruding iron will of course engage the board but not if you start in the middle.
Then one increase the depth which will only cause taking bigger chunk at the edge but with no improvement in the middle. Then one push hard downward, with the described results.
I have been there.
Did you ever figure out the reason this was happening? I'm having the same problem. New No 4. Stones are flat. Blade appears to be flat. I am thinking It is my honing jig (inexpensive eclipse style), but not sure.
Have you tried holding a ruler up to the edge. I use the blade out of a starrett square to see how much camber is in my blade. A couple times I saw a hollow in my edge. I said to myself that's odd.
Good Luck
Hmmm…usually means there is something under the iron….like a small chip about in the middle of the edge of the iron…holding it up in the middle….Chipbreaker is then forcing the corners down.
Here's a sample cut that shows what I mean. And I tried to take a picture of the light reflecting off of the blade (different on edges than center).
AJ - I did hold a straightedge up to it. Hard to detect. I was troubleshooting and when sighting down the sole of the plane and while advancing the blade, I could see BOTH edges before the center. Very slight.
Bandit - Chipbreaker seems to be making solid contact without obstruction…
Sanderguy - Sole of the plane seems dead on (brand new LN) as far as I can tell. I just went and triple checked because that would make sense.
Full disclosure - I spent a day regrinding the primary bevel on sandpaper, and then noticing I was way off square and doing it again. Haha. That's the reason for the multiple bevels in the picture. I've made a bit of a mess of the blade but has been a good learning experience. But - same result. Seems to be a hollow in the center!
My next thought is still to buy a nicer honing guide. Probably a good thing to get anyways but not sure if it'll fix my problem!
That inexpensive exlipse clone has worse casting than we did in Jr High metal shop. And its common for them to bend the iron due to how bad it is. Simple fix though with a decent file and about an hour work. Ironically, Lie Nielsen has a good video on fixing it even though they sell a really high end honing jig:
- SMP
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
