End Grain Cutting Board - Gaps After Second Glue up
Forum topic by CLS89 posted 02-03-2019 09:19 PM 766 views 0 times favorited 7 replies Add to Favorites Watch
View CLS89's profile
CLS89
4 posts in 377 days
02-03-2019 09:19 PM
I am beginner woodworker and I am getting ready to finish my first end grain cutting board. I used purple heart and hard maple for this project. I don’t have a jointer and a thickness planer, so I created a router flattening sled to face joint the first glue up. Problem is I believe there is something wrong with my setup because the jig didn’t plane the first glue-up perfectly flat. I believe the sled/gantry and the rails it sits on are flexing. I will reconfigure. However, I went ahead and did the second glue-up. Obviously, the boards don’t sit flush with one another. The attached photo was taken before I glued and clamped the pieces, so the gaps in the final product will be smaller, but I still expect them to be there, so I need to be ready to fill them before final flattening and sanding. My plan is to fill the gaps with ether an food safe epoxy or glue + saw dust once the glue-up drys. Which of these two options would work best for this type of problem? Are there additional solution’s? Please advise. Thanks
7 replies so far
View Snipes's profile
Snipes
432 posts in 2749 days
#1 posted 02-03-2019 10:25 PM
if the gap is small enough sand while glue is wet and it will disappear
-- if it is to be it is up to me
View hookup's profile
hookup
17 posts in 228 days
#2 posted 02-28-2019 03:14 AM
sawdust mixed with wood glue will fill the gaps
View Aj2's profile
Aj2
2475 posts in 2302 days
#3 posted 02-28-2019 03:30 AM
There shouldn’t be any gaps on cutting boards. Maybe you should stick to long grain boards simple stuff till you get a jointer planer.
-- Aj
View diverlloyd's profile
diverlloyd
3636 posts in 2361 days
#4 posted 02-28-2019 03:35 AM
How bad is the gap once you have clamping pressure on it?
View LittleShaver's profile
LittleShaver
582 posts in 1124 days
#5 posted 02-28-2019 06:19 PM
Those look like they will close with clamping pressure. Use cauls, use lots over and under, and crank them tight.
-- Sawdust Maker
View bondogaposis's profile
bondogaposis
5538 posts in 2855 days
#6 posted 02-28-2019 07:26 PM
Do the glue up in sections and I bet you will be able to close the gaps.
-- Bondo Gaposis
View ArtMann's profile
ArtMann
1432 posts in 1320 days
#7 posted 02-28-2019 11:18 PM
I agree with Bondo. You will get better results easier if you will glue it up in sections rather than all at once.
