New with scroll saw questions about blade type
« back to Scrollsawing forum
Forum topic by EBatson posted 02-01-2019 01:48 AM 618 views 0 times favorited 10 replies Add to Favorites Watch
View EBatson's profile
EBatson
6 posts in 1100 days
02-01-2019 01:48 AM
Got an older 16” Craftsman scroll saw at a church yard sale, came with several blades. I’ve been playing around with it some and I Think I can translate bandsaw skills to it fairly easily. The old blades seem to have some tear-out, so I need new ones before I try with wood that actually matters. I’m wanting to do a project with 1/2 to 3/4 inch cherry. What type of blade(s) should I get to make smooth cuts? Smallest radius probably 1/2 inch. Thanks for any ideas.
10 replies so far
View Kelly's profile
Kelly
3046 posts in 3743 days
#1 posted 02-01-2019 02:47 AM
For straight line sawing, bigger is better, so your half inch bet is probably good. I do a lot with a 1/2” on my 14” PM.
I usually buy 3 or 4 TPI blades so I can do thicker stuff. For 3/4”, you “might” get by with a 6 TPI, but I just plan on dealing with the tooth marks left using the 4 TPI.
View wichman3's profile
wichman3
97 posts in 1420 days
#2 posted 02-01-2019 03:01 AM
EBatson: pin end or plain?
Kelly, he’s asking about a scrollsaw not a bandsaw.
EBatson
#3 posted 02-01-2019 03:18 AM
Yep, scroll saw. And 5 inch pin end. Thanks
Kelly
#4 posted 02-01-2019 03:40 AM
Oops. I was blowing through posts a bit too fast, it seems.
wichman3
#5 posted 02-01-2019 04:13 AM
- Kelly
no worries :)
wichman3
#6 posted 02-01-2019 04:40 AM
Got an older 16” Craftsman scroll saw at a church yard sale, came with several blades. I ve been playing around with it some and I Think I can translate bandsaw skills to it fairly easily. The old blades seem to have some tear-out, so I need new ones before I try with wood that actually matters. I m wanting to do a project with 1/2 to 3/4 inch cherry. What type of blade(s) should I get to make smooth cuts? Smallest radius probably 1/2 inch. Thanks for any ideas.
- EBatson
1/2 radius should not be a problem with most common blades, as fro the tear-out try some scroll reverse blades; these blades have 5 or 6 teeth on the bottom of the blade reversed to reduce tear-out. Lowes or Home Depot should have multi packs (several sizes) so you can try different sizes and see what works best for you .
MrUnix
8141 posts in 2998 days
#7 posted 02-01-2019 06:24 AM
Regular blades will produce tearout even when new, so those blades that came with the saw may be just fine. Wrapping in tape or sandwiching between two thin sheets of ply will reduce it significantly. Unfortunately, needing pin end blades will reduce your selection considerably. I believe they made kits to convert the machine to use plain end blades, which would give you a much wider choice of blades.
For what you are looking at cutting, I’d be looking at something like a #5 or #7 reverse tooth blade (Olson selection chart here) or similar. I find #5 to be a pretty good all purpose blade for a wide variety of applications… smaller ones are good for thin work with intricate detail, like on portraits – and wider ones are good for thick stock work, like desk name plates and stuff.
View Redoak49's profile (online now)
Redoak49
4794 posts in 2788 days
#8 posted 02-01-2019 11:33 AM
MrUnix gave good advice with the chart.
Scroll Saw Village forum is a very good source of information for you.
EBatson
#9 posted 02-01-2019 12:25 PM
Thanks. MrUnix, you helped clear up all the vocabulary. Now I have a good idea of what to look for.
EBatson
#10 posted 02-01-2019 04:15 PM
And Scroll Saw Village looks good if I get the scrollsaw bug, got it bookmarked.
