Drill stops - do they work?
Forum topic by unclearthur posted 01-31-2019 04:19 AM 1366 views 0 times favorited 25 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
383 posts in 2870 days
01-31-2019 04:19 AM
OK, I know this isn’t a major issue, but I am annoyed at these things:
They:
- go crooked when you tighten the locking screw
- slip when you actually use them
- snap your drill bit in two if you tighten the locking screw too much.
At least thats my experience with my $6 for 5 drill stops from Amazon.
Do the more expensive ones work any better?
25 replies so far
View mtnwalton's profile
mtnwalton
100 posts in 2108 days
#1 posted 01-31-2019 04:24 AM
Those are set collars used in industry as a stop for the size shaft their hole is, not intended for use on drill bits. However if you size them carefully and locate the set screw properly they can be used as such
unclearthur
#2 posted 01-31-2019 04:34 AM
- mtnwalton
Amazon says differently!
How do you locate the set screw properly? Maybe I’m doing something wrong?
mtnwalton
#3 posted 01-31-2019 04:40 AM
Not the first time Amz has been wrong. I’m a retired machinist 38 years and at least in this part of the country they are called set collars.
locate the set screw on the outer part of the flute. Not ideal, but it works
21408 posts in 2938 days
#4 posted 01-31-2019 04:47 AM
I find masking tape works just as well.
View Rayne's profile
Rayne
1319 posts in 2621 days
#5 posted 01-31-2019 05:01 AM
You need something like this. The set screw doesn’t sit against the drill bit. These collars get tightened around the bit itself. The link is just an example. I’m sure there are better versions of this.
https://www.amazon.com/Aluminum-Stop-Collar-Set-Superior/dp/B06XTD5KXB/ref=sr_1_1_sspa?ie=UTF8&qid=1548910823&sr=8-1-spons&keywords=drill+bit+stop+collar&psc=1
6986 posts in 3575 days
#6 posted 01-31-2019 11:34 AM
I have the split ring design and like them much better for the reasons you described.
View John Smith's profile
John Smith
2925 posts in 1244 days
#7 posted 01-31-2019 11:46 AM
I have a set of those “collars” with the hex set screw that I have not
used in decades – ever since I found masking tape. (as Fire stated).
(free plus postage to anyone that wants a nice set of vintage collars).
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View Gene Howe's profile
Gene Howe
12325 posts in 4510 days
#8 posted 01-31-2019 12:11 PM
Tape does work. So does a piece of scrap, if your boring a bunch of holes.
I’ll add my set to John’s. Practically unused.
View RobHannon's profile
RobHannon
347 posts in 1612 days
#9 posted 01-31-2019 01:24 PM
I gave up on the collars in favor of tape as well. If I need a precise depth I sneak up on it or use the drill press. Only stop on a bit that I have found to be useful is the one that is integrated in my countersink.
View Nubsnstubs's profile
Nubsnstubs
1774 posts in 2812 days
#10 posted 01-31-2019 02:18 PM
Use a small piece of wood. Drill through it, then insert the bit into the chuck measuring how much the drill bit protrudes and tighten the chuck. If the bit is too long, get a thicker piece of wood. Math is your friend on a situation like this. Besides, wood on wood is a lot friendlier than metal on wood. I would use wood stops instead of the metal, but also use tape if the depth is not precise.
I have a bunch of these when working in aviation, but rarely use them in wood working. They are collecting dust like others mentioned
https://www.mscdirect.com/product/details/43234004 ................... Jerry (in Tucson)
View HokieKen's profile
HokieKen
17546 posts in 2220 days
#11 posted 01-31-2019 02:18 PM
In order for a stop to be effective on a drill, it needs to be precisely sized to fit that size drill rod and have a clamping action rather than a set screw. Even then, 99% of the time, masking tape is just as effective. I have a set of collars but I’m not as generous as John and Gene. They may yet find a purpose in my shop ;-)
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View Fresch's profile
Fresch
520 posts in 3002 days
#12 posted 01-31-2019 03:12 PM
Put the stop on the shaft then Stack washers.
Or put it in your Shopsmith adjust the travel and have at it!
Gene Howe
#13 posted 01-31-2019 05:01 PM
In order for a stop to be effective on a drill, it needs to be precisely sized to fit that size drill rod and have a clamping action rather than a set screw. Even then, 99% of the time, masking tape is just as effective. I have a set of collars but I m not as generous as John and Gene. They may yet find a purpose in my shop ;-)
- HokieKen
When that purpose is found, please share it. In the meantime, my offer stands. Not generosity, just house cleaning.
HokieKen
#14 posted 01-31-2019 05:04 PM
- HokieKen
- Gene Howe
Will do Gene. Please don’t hold your breath though ;-)
View Sparks500's profile
Sparks500
280 posts in 1412 days
#15 posted 01-31-2019 05:30 PM
I tried all the different drill stops and realized, much like half the stuff at woodworking shows, it’s snake oil.
Masking tape. Leaves no marks, works perfectly, costs nothing.
KISS method is always the best.
-- A good day is any day that you're alive....
