Need Help... How to deal with this trim issue (trim reveal / trim proud)
Forum topic by RickDel posted 01-27-2019 07:24 PM 1522 views 0 times favorited 15 replies Add to Favorites Watch
View RickDel's profile
RickDel
58 posts in 1011 days
01-27-2019 07:24 PM
I hope I put this in the right forum.
Hello, I’m a beginner woodworker who building a window cornice box similar to this:
However, I want to use corner trim in my build. My problem is the corner trim is proud of the bottom trim it butts into by about a 1/16th of a inch”. Here’s a couple scrap pieces to see what I’m talking about:
What’s the best solution for this situation? A couple things I’ve considered were just lightly sanding the edge of the corner trim (making it flush to the bottom trim) and caulking or maybe running the corner trim across the jointer to reduce it a 1/16” but I’m not sure that would even work. Any ideas or suggestions are greatly appreciated! (BTW, I may be overthinking this too…. it might look fine with a little caulk and paint, I just don’t want to risk it without getting some experienced advise) .
Thanks – Rick
15 replies so far
View gwilki's profile
gwilki
367 posts in 2690 days
#1 posted 01-27-2019 09:14 PM
It’ s bit confusing since your first picture has nothing in common with the others.
You don’t say what tools you hare , but if you want the horizontal piece in your pics to be in the plane as the vertical, you could plane some off the backside of the horizontal piece.
-- Grant Wilkinson, Ottawa ON
View Ripper70's profile
Ripper70
1379 posts in 2125 days
#2 posted 01-27-2019 09:21 PM
Agreed that the pics are confusing. Another option, and maybe a simpler one to the suggestion by gwilki, is to add a strip of wood to the back of the vertical piece to bring it in line with the other.
However, it would help to have more context to your pics and to know what tools you have available to get the job done.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View Peteybadboy's profile
Peteybadboy
3893 posts in 3166 days
#3 posted 01-27-2019 09:30 PM
Plane it thinner? or bend in the end ( i.e. SAND , FILE) to match the piece it is butting up to.
-- Petey
RickDel
#4 posted 01-27-2019 09:41 PM
My first pic is of what I’m building, in case anyone was unfimiliar with a “cornice box”. One difference in my build is I want to add corner molding to at the corners.
My pics posted sideways but they show a mock up of what I have. I took a piece of corner trim and butted it up to the bottom trim. Might be difficult to see, but the corner trim is 1/16” proud of the bottom trim. I don’t want that and I’m curious how experienced guys would deal with this? Looks like gwilki suggests planning the corner trim down and Ripper70 suggests building the bottom trim up.
Thanks
RickDel
#5 posted 01-27-2019 09:43 PM
SAND , FILE to match the piece it is butting up to.
- Peteybadboy
Petey, I was wondering if I could do that. It’s a 1/16 of an inch. You think I can do that without it being noticeable? Thanks
View clin's profile
clin
1128 posts in 2212 days
#6 posted 01-27-2019 09:47 PM
You could add detail to the end of the thicker corner trim (a bead or similar) rather than just round it off as you have in the photo. What would look good depends on the overall design.
I also agree with the idea of simply thinning out the corner trim. If you have a table saw, you could run it through to make it thinner. Or as mentioned use a hand plane.
I also agree with making the main trim thicker. By that I mean the trim that is vertical in your photos. Though I believe that is in fact the horizontal trim.
It is common to build up trim by layering simpler pieces on each other. Though don’t try to align the edges of pieces flush. I.E. don’t try to make the molding look thicker. That will show. Rather, step them one to the next. Make the new piece as thick or thicker than the corner trim and step it to the piece you already have.
Below is not an example of your situation, but it illustrates how you can build up molding from several pieces to create whatever you want.
-- Clin
View Jared_S's profile
Jared_S
470 posts in 1176 days
#7 posted 01-27-2019 09:57 PM
Your corner stock needs to be thinner, if you keep the bottom moulding upside-down.
You could just flip the bottom moulding the other way.
RickDel
#8 posted 01-27-2019 10:04 PM
Thanks for all the great advice….
- Jared_S
Jared, That was a thought too, so here’s a newbie question… Isn’t that trim supposed to go with the wide part at the bottom? If I flipped it, wouldn’t that be noticeably wrong? Like when people install crown upside down.
Thanks
View Bunyon's profile
Bunyon
18 posts in 1481 days
#9 posted 01-27-2019 10:27 PM
When I run into a situation like this, I always build the bottom trim up. A small piece 1\4” thick is all you need and you can make it invisable by the time it’s painted. In this case you may have to build up your crown moulding as well
-- Living the dream up here in Strathroy, Ontario, Canada
View John Smith's profile
John Smith
2998 posts in 1379 days
#10 posted 01-28-2019 12:07 AM
Bondo is your Friend
-- I am a painter: that's what I do, I like to paint things. --
View TungOil's profile
TungOil
1384 posts in 1711 days
#11 posted 01-28-2019 12:19 AM
You are over thinking this. Just round it over with some sandpaper and be done with it.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View squazo's profile
squazo
295 posts in 2861 days
#12 posted 01-28-2019 01:27 AM
have the moldings cut so they butt up the other way.
or install a plinth block. This is what I would do.
Ripper70
#13 posted 01-28-2019 02:13 AM
This makes it a bit more clear…I think…
Still, I think building the profiled trim up to make it appear thicker is the way to go.
RickDel
#14 posted 01-28-2019 02:31 AM
Thanks guys…. I got the answers I needed.
John Smith
#15 posted 01-28-2019 12:35 PM
Rick – this is a similar situation on my kitchen island trim.
I just sanded the end of the trim down to fit, caulked the joint, primed and painted.
after the countertop is permanent, I will run a bead of white
caulk along the top edge and it will pass any inspection.
now, if you are going to use nice wood and a clear coat, much more
attention to detail will be required. but just for paint; caulk it and call it a day.
good luck in your projects.
