Looking for slot cutter for 1/4" MDF
Forum topic by Robert posted 01-23-2019 09:39 PM 742 views 0 times favorited 14 replies Add to Favorites Watch
View Robert's profile
Robert
3709 posts in 2219 days
01-23-2019 09:39 PM
I need to build a bunch of flat panel cabinet doors with 1/4” MDF panels. The MDF I’m using measures ~ 5.25mm.
The slot cutter that comes with the profile set measures 5.5mm. It seems like it should work, but there is too much slop and a noticeable gap, and a rattle.
I have not been able to find a slot cutter that will work. I’m using a CMT shaker set that has a a 5/16” arbor, 1 3/4” diameter.
Looking for help on this, as well as other options. I’ve thought about removing the slot cutter and plowing the grooves with a dado blade. Or buying an adjustable slot cutter set and shimming it up.
CMT has since replaced the set I’m using with a adjustable slot cutter, but I don’t want to buy a whole ‘nother bit set.
I’ve never used 1/4” MDF in the past I’ve always used 1/2” and the panel raiser set flush. I’m thinking maybe this is the simplest solution.
14 replies so far
View mnguy's profile
mnguy
300 posts in 4137 days
#1 posted 01-23-2019 09:57 PM
Can you have the 5.5 mm cutters ground down to 5.25 mm by a sharpening shop? Alternatively, a lot of minutes with a diamond paddle?
View Jared_S's profile
Jared_S
346 posts in 698 days
#2 posted 01-23-2019 11:40 PM
Source different mdf?
1/4” sheets I get measure .010” heavy at .260”
View AlaskaGuy's profile
AlaskaGuy
5734 posts in 3048 days
#3 posted 01-24-2019 12:06 AM
I have done this before but my MDF fit my groves.
If it were me I wouldn’t change my stile and rail set up. I modify the the panel. Like in this drawing but you you would be taking off very little.
If you do have access to 3/8 thick material the extra weight would make you door feel more substantial.
View therealSteveN's profile
therealSteveN
5594 posts in 1313 days
#4 posted 01-24-2019 12:39 AM
Faced with rattle, and a difference of .25mm I would be looking at a much cheaper fix. Space balls or more likely a good quality of caulk, squeezed out into very thin lines on a sheet of waxed paper. Freeze them. Insert them, and forget, your slop, wiggle, rattle it’s gone. Just make sure to inset the cutter enough to not get squeeze out. 3/8 should do. On MDF it’s like magic. Do a trial test on a few pieces of scrap.
I use a syringe, NO needle. I keep both 60 MM and the 10 MM in the shop. As useful as that third hand
-- Think safe, be safe
View JAAune's profile
JAAune
1876 posts in 3055 days
#5 posted 01-24-2019 03:18 AM
If you pre-finish the panels then extra thickness of the added finish might take out some of the rattle.
View bigJohninvegas's profile
bigJohninvegas
771 posts in 2200 days
#6 posted 01-24-2019 03:27 AM
Why not cut the slots on a table saw?
-- John
Robert
#7 posted 01-24-2019 02:39 PM
I agree I changed the bit setup one time—not something I would look forward to.
Checked with my supplier they do carry 3/8” MDF. Problem solved, Thx AKGuy !!
FYI to everyone CMT now carries an adjustable rail/stile bit set.
- JAAune
Good point, but the main point of using MDF is to shoot the doors after assembly.
The rattling is from panel/groove gap. Spacers won’t help that. In the past I have used caulk, but for me its a cheesy fix.
View Jack Lewis's profile
Jack Lewis
576 posts in 1817 days
#8 posted 01-24-2019 03:22 PM
I use a syringe, NO needle. I keep both 60 MM and the 10 MM in the shop. As useful as that third hand The rattling is from panel/groove gap. Spacers won t help that. In the past I have used caulk, but for me its a cheesy fix.
- rwe2156
“Cheesy fix” It’s MDF for gawd sake!
-- "PLUMBER'S BUTT! Get over it, everybody has one"
therealSteveN
#9 posted 01-25-2019 06:49 AM
- rwe2156
“Cheesy fix” It s MDF for gawd sake!
- Jack Lewis
It makes a LOT more sense if you drag the rest of the thought along with it. Or are you just trying to pick a fight??
I wrote
“Faced with rattle, and a difference of .25mm I would be looking at a much cheaper fix. Space balls or more likely a good quality of caulk, squeezed out into very thin lines on a sheet of waxed paper. Freeze them. Insert them, and forget, your slop, wiggle, rattle it’s gone. Just make sure to inset the cutter enough to not get squeeze out. 3/8 should do. On MDF it’s like magic. Do a trial test on a few pieces of scrap.
I use a syringe, NO needle. I keep both 60 MM and the 10 MM in the shop. As useful as that third hand”
The link was to WC syringes, which is where I get mine now that I am no longer working as an RN. I use them to inject the caulk, much more efficient than a caulking gun, and you can make very fine lines.
Robert
#10 posted 01-25-2019 02:12 PM
Didn’t mean to offend I’ve done the caulk thing before just not for me. Maybe cheesy was the wrong word.
I’ve got about 25 doors to make.
Rather use the 3/8 mdf than futz around with caulking.
Jack Lewis
#11 posted 01-25-2019 03:00 PM
- rwe2156
- Jack Lewis
- therealSteveN
And I wrote “Cheesy fix” It s MDF for gawd sake! ” How does MDF even satisfy the “do it perfect attitude” of some people. He is not going to put a French Polish on the cabinets! There is only so much you can do to “MDF” . Now my so called “trying to pick a fight” is put into perspective. MDF the choice of fine wood workers everywhere.
Jared_S
#12 posted 01-25-2019 08:21 PM
- Jack Lewis
Actually your explanation of the comment seems worse than the original comment…
Saying the craftsmanship is irrelevant because it’s MDF is ridiculous.
There are lots of custom $100,000+ kitchens with mdf door / drawer panels.. you may not like it, but it doesn’t make it any less true.
AlaskaGuy
#13 posted 01-26-2019 12:26 AM
- Jack Lewis
Saying the craftsmanship is irrelevant because it s MDF is ridiculous.
There are lots of custom $100,000+ kitchens with mdf door / drawer panels.. you may not like it, but it doesn t make it any less true.
- Jared_S
Exactly. A lot of hobbyist have no clue of the benefits of MDF, Melamine etc. in certain applications. Many badmouth those product and have never used them. They really no very little about them. They just read somewhere it’s bad and keep repeating. Tell a lie long enough and people will start to believe it just on hearsay.
View pottz's profile
pottz
9513 posts in 1723 days
#14 posted 01-27-2019 04:06 AM
- Jack Lewis
- Jared_S
sorry jared but im with jack on this one,im not payin no 100k for a mdf kitchen!. if you can sell that good luck,and soory for the fool that buys it!
