Need ideas on what could be happening
Forum topic by SalvagedandCompany posted 01-22-2019 10:59 PM 558 views 0 times favorited 6 replies Add to Favorites Watch
View SalvagedandCompany's profile
SalvagedandCompany
6 posts in 597 days
01-22-2019 10:59 PM
So after jointing and planing I go to rip the 4th edge and the beginning of the cut is square but the last inch of the board isn’t. It looks like my blade is taking extra off on the last inch. It’s a new blade, the blade is 90 to the miter slot, splitter is perfect. I will put pictures to get a better idea
View Rayne's profile
Rayne
1216 posts in 2023 days
#1 posted 01-22-2019 11:05 PM
Is the fence square to the miter slot?
View mrg's profile
mrg
860 posts in 3483 days
#2 posted 01-22-2019 11:09 PM
Are the teeth even coming above the board? Photo the teeth look to be below the surface.
-- mrg
View pontic's profile
pontic
697 posts in 1092 days
#3 posted 01-22-2019 11:13 PM
- mrg
I think this also judging from the pictures. Got to get the blade’s gullets above the wood.
-- Illigitimii non carburundum sum
View Thomas0072's profile
Thomas0072
1 post in 243 days
#4 posted 01-22-2019 11:18 PM
I had a similar problem. I could see the blade move back toward the fence as the wood passed through the blade. I tightened the blade and readjusted the splitter. Seemed to have solved my problem.
SalvagedandCompany
6 posts in 597 days
#5 posted 01-23-2019 12:43 AM
I lowered the blade to show what it is doing. Fence is square to miter. I found if I raise the blade all the way up it reduces the bite to about half inch. Thomas0072 I think that sounds like a good solution.
SalvagedandCompany
6 posts in 597 days
#6 posted 01-24-2019 06:25 PM
*update- I basically took the whole saw apart and readjusted everything from the fence, spiltter , blade to miter slot. It still does it, so the only new thing is my blade. It’s a brand new ridge carbide blade so I didn’t think that could be the problem but it was!! I put a older blade on and sure enough it worked perfect. Pretty crazy.
