Forum topic by PPBart | posted 01-19-2019 03:17 PM | 670 views | 0 times favorited | 13 replies | ![]() |
I’m preparing to build StumpyNubs’ Router Lift and my plan is to use a piece of 3/8” thick Lexan for the table. I’ve not done much work with plastics, and in reviewing YouTube videos on the topic it seems that some folks treat Lexan/Plexiglass/Acrylic in the same manner. From a practical real-world position, what will I need to use and to be careful of in cutting the plate to size and in drilling holes up to 1.5” diameter in the plate? -- PPBart |
13 replies so far
#1 posted 01-19-2019 06:51 PM |
I use the same woodworking tools on plastics that I use on wood. . . -- there is no educational alternative to having a front row seat in the School of Hard Knocks. -- |
#2 posted 01-19-2019 07:02 PM |
Lexan is a good choice. As john said, it can be worked with woodworking tools. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#3 posted 01-19-2019 07:07 PM |
Besides what John had to say I have found that drilling holes in thicker plastic has one additional problem. The bit tends to really grab plastic as it cuts so make sure you have the piece well secured (clamped down) and good control of the drill. The latter in most cases (with thick plastic) means using a drill press to control the feed speed of the bit. -- Les B, Oregon |
#4 posted 01-19-2019 09:11 PM |
Lexan is a good choice because it is very tough, much more so than acrylic. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#5 posted 01-19-2019 09:20 PM |
Polycarbonate can be cut with power tools. Acrylics will re-fuse itself on the cut lines. The heat the tool produces melts the plastic. Polycarbonate will not do this. |
#6 posted 01-19-2019 10:58 PM |
Just out of curiosity, how big is the unsupported span of the lexan? 3/8” is not very thick, if hanging a heavy router and a lift from the bottom of it. If the span is very big, it will sag over time, I would bet. -- Grant Wilkinson, Ottawa ON |
#7 posted 01-20-2019 01:54 AM |
The plate finished dimensions will be about 11.5” square, unsupported span about 10” square. The router installed will be a Porter-Cable 1.75 HP. If it does eventually sag a bit, I’ll just replace it with something thicker. -- PPBart |
#8 posted 01-20-2019 02:10 AM |
Personally I would not use Lexan. I would use a phenolic based board, like bakelite. It is stiffer and won’t sag over time. It is expensive, about $44 a sq ft. I use it on my router table. |
#9 posted 01-20-2019 02:18 AM |
Lexan is a good choice… Can I use Forstner bits for the largest hole (1.5”)? -- PPBart |
#10 posted 01-20-2019 02:23 AM |
Personally I would not use Lexan. I would use a phenolic based board, like bakelite… I never thought of bakelite, but I’ll keep it in mind for the next time. -- PPBart |
#11 posted 01-20-2019 06:55 PM |
Lexan is a good choice… I’ve never tried it, but I don’t think a forstner bit will cut lexan. A brad point bit or a hole saw might work better. Try it out on a scrap piece. |
#12 posted 01-23-2019 05:10 AM |
I ve never tried it, but I don t think a forstner bit will cut lexan. A brad point bit or a hole saw might work better. Try it out on a scrap piece… I had some scrap pieces of 1/8” Lexan, so I tested — standard twist drills up to 1/2” seemed to cut fine, nice clean holes. Then I jumped up to a 1.5” Forstner bit — it too cut just fine. I think I’ll be OK if I keep speed/pressure down. -- PPBart |
#13 posted 01-23-2019 10:33 PM |
Great! Thanks for the report on using a forstner bit on lexan. That I didn’t know. |
Forum | Topics |
Woodworking Skill Share
13139 |
Woodturning
2783 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1869 |
Finishing
6302 |
7856 |
32534 |
CNC Woodworking
325 |
Hand Tools
6421 |
Jigs & Fixtures
1784 |
Wood & Lumber
7244 |
1613 |
Focus on the Workspace
2615 |
1267 |
Woodworking Trade & Swap
5394 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9626 |
