Belsaw belt adjustment?
Forum topic by Derrick posted 01-10-2019 12:25 AM 215 views 0 times favorited 4 replies Add to Favorites Watch
View Derrick's profile
Derrick
103 posts in 1592 days
01-10-2019 12:25 AM
Hello,
A while back I purchased a Woodmaster 612, which I’m told is all Belsaw underneath the sheet metal.
http://lumberjocks.com/topics/178066
I haven’t fired it up since the day it was purchased. Today I decided to do so.
I just wanted to run a couple test pieces through. Really, I just wanted to make sure it still worked.
I was able to test the jointer attachment. I don’t think I’ll be doing that again.
I kept throwing a belt, and wasn’t able to use the planer.
I know nothing about these, but I’m assuming it moves the feed rollers?
Does anyone know how to make adjustment to this, to tighten the belt?
I don’t want to tear into it before I have a game plan.
Thank you.
Derrick
View wichman3's profile
wichman3
95 posts in 1075 days
#1 posted 01-10-2019 04:25 AM
http://www.hawkwoodworkingtools.com/files/Planer/model612Planer.pdf
Is this your machine? full operators manual including belt adjustments. :)
wichman3
#2 posted 01-10-2019 04:27 AM
Also, that small belt may have developed a “set”, if it has you will need to pull it off the machine and address that issue separately.
Derrick
#3 posted 01-10-2019 05:25 AM
Thank you for that!! I just found some part numbers over on the Belsaw site as well. Looks like I’ll be tearing into this soon, to try and figure out what’s wrong. That’ll be a good time to ditch the jointer attachment too.
Derrick
#4 posted 01-11-2019 06:16 AM
Well,
It appears to be an easy fix. The pulley that the belt rides on is real loose. Looks like it takes a small allen to tighten back up. The belt itself was only $3 on Amazon. I’m just going to swap it out anyways.
I think I have an understanding how to disassemble enough to replace the belt. I should be back up and running in no time.
