Grizzly Table Saw Arbor Wrench
Forum topic by BoilerUp21 posted 01-06-2019 03:14 AM 433 views 0 times favorited 9 replies Add to Favorites Watch
View BoilerUp21's profile
BoilerUp21
131 posts in 1153 days
01-06-2019 03:14 AM
While i have no complaints about my Grizzly 1023 RLWX Table Saw, the arbor wrench that came with it may of well be made out of plastic…After only using it a handful of times, it is bent so badly where the mouth is, that it slips off every time i try and loosen the bolt on the other side of the blade. Does anyone know where or who makes one that is reliable? Regular wrenches are too thick to fit, and i do not want a replacement from Grizzly, as it will end up bent in no time due to the complete lack of quality,
9 replies so far
View sawdustjunkie's profile
sawdustjunkie
405 posts in 2103 days
#1 posted 01-06-2019 03:23 AM
I would go get a correct mm wrench from Home Depot and grind the sides flat till it fits.
I have the 690 and use those wrenches, but I didn’t need to grind them down.
-- Steve: Franklin, WI
BoilerUp21
#2 posted 01-06-2019 03:25 AM
Will do, probably the cheapest and quickest solution. Thanks!
View Jared_S's profile
Jared_S
196 posts in 345 days
#3 posted 01-06-2019 04:23 AM
I use a tappet wrench on mine
View MrUnix's profile
MrUnix
7383 posts in 2585 days
#4 posted 01-06-2019 04:46 AM
Are you referring to the stamped steel open end wrench to grab the flats on the arbor? I have a drawer full of those things because they are pretty much useless and not worth the time or effort. Any standard wrench will work for the arbor nut – and all you need is that and a scrap piece of wood to remove/install the blade. Simple and easy.
runswithscissors
3038 posts in 2411 days
#5 posted 01-06-2019 05:09 AM
Don’t buy a new arbor wrench. Go to your local pawn shop and go through the bin of open end or combination wrenches until you find the right size. Will probably cost you 50 cents to a buck. Grind it down until it’s thin enough to fit. Use a bench grinder or right angle grinder.
View therealSteveN's profile
therealSteveN
2796 posts in 960 days
#6 posted 01-06-2019 05:51 AM
Where is a standard open/box wrench having trouble fitting on? I don’t own this saw. but untouched they (standard wrenches) have worked well on saws of a number of manufacturers as is.
Before I started grinding away on a perfectly good wrench I would try it, lest you make another wrench that simple hand pressure could bend up. Seems you’ve already been down that road.
Owners Manual doesn’t give an actual size for the arbor nut, but it sure looks like what I would expect.
-- Think safe, be safe
View GR8HUNTER's profile
GR8HUNTER
6065 posts in 1098 days
#7 posted 01-06-2019 01:57 PM
sorry but I am having a hard time believing that you cannot get a regular wrench in there I can get my whole hand in there :<))
Jared_S
#8 posted 01-06-2019 02:31 PM
He is talking about the wrench that holds the arbor..
Not the Arbor nut
GR8HUNTER
#9 posted 01-06-2019 02:50 PM
Not the Arbor nut
- Jared_S
sorry sometimes I’m an idiot you are correct sir and I apologize to boiler :<((((((((((((
