Rust
Forum topic by Joe Bigham posted 01-04-2019 08:04 PM 463 views 0 times favorited 9 replies Add to Favorites Watch
View Joe Bigham's profile
Joe Bigham
10 posts in 328 days
01-04-2019 08:04 PM
Before I make a bad choice, are there any issues with spraying shellac on my tablesaw and bandsaw? I have seen a few posts where it was used as a rust preventative.
My area is VERY humid and my building is not climate controlled. (plus I tend to like to keep doors open)
I have been using johnsons but walked in lastnite to find rust everywhere.
Thanks for any advice.
9 replies so far
View squazo's profile
squazo
140 posts in 2187 days
#1 posted 01-04-2019 09:56 PM
shellac is alcohol based so I would think it should be safe. How well it would work and how long it would last, who knows? Hell I’d give it a go, if it doesnt work or makes things worse just take it off.
View wuddoc's profile
wuddoc
353 posts in 4260 days
#2 posted 01-04-2019 10:19 PM
Joe you may wish to check out: lumberjocks.com/reviews/9777
I have used it in the school shop for decades. Sprayed and wiped before summer vacation we would return and still be rust free. I still use it in my personal shop.
-- Wuddoc
View CaptainKlutz's profile
CaptainKlutz
1955 posts in 2036 days
#3 posted 01-04-2019 11:56 PM
What ever you apply, make sure you strip the old wax/grease/crud from the cast iron first.
Another current thread on same topic:
http://lumberjocks.com/topics/302350
View Holbs's profile
Holbs
2249 posts in 2571 days
#4 posted 01-05-2019 01:34 AM
I am actually curious how you have new rust after applying wax. Mysteries of the universe.
As Capt says… I could only think of underlying film of…something under the applied wax.
have you tried out um…um…. Boeshield T9 (I think)?
Joe Bigham
#5 posted 01-05-2019 02:25 AM
- wuddoc
I picked up a can of the spray shellac to try, if it doesn’t work out I will order some of that. Thank you very much
Joe Bigham
#6 posted 01-05-2019 02:30 AM
- CaptainKlutz
I picked up a can of mineral spirits to clean the wax off
Joe Bigham
#7 posted 01-05-2019 02:35 AM
- Holbs
No so far I have only used johnsons wax, and normally I put a tarp over each tool when I lock up. I didn’t put tarps on and was gone for 3 days and came back to a mess. spent an hour with pb blaster and a scotch pad then put 2 new coats of wax.
View Kelly's profile
Kelly
2468 posts in 3486 days
#8 posted 01-05-2019 05:44 AM
The best results I ever had was and is by using Corrosion-X (not the super, commercial version, which stays tacky). You, literally, can put a coke on my cabinet saw and it will not rust.
The down side is, after bringing my table top to a mirror like surface (using my spent granite polishing pads and a bit of oil), the Corrosion X made that beauty go away.
Read up on it. It’s what it’s touted to be.
You will need to wax or otherwise slicken the surface after application.
View Aj2's profile
Aj2
2534 posts in 2340 days
#9 posted 01-05-2019 06:12 AM
I use shellac on my hand wheels ,knobs,t-handles. Just left over batches that I don’t want to waste. I got a tip about its rust protection and it does seem to protect better then wax.
One difference I use real shellac dissolved in alcohol. Not sure what that stuff in the can is.:)
-- Aj
