Forum topic by zipmac22 | posted 01-01-2019 09:44 PM | 728 views | 0 times favorited | 7 replies | ![]() |
I have a Dewalt 735 planer that I used the first time a week ago and put about two dozen boards (1×6x6) through it. Today I tried to use the planer and it won’t feed any boards. I’m puzzled as to what is causing the planer not to work. What should I be looking for to get the planer working? -- Chris, Central Texas |
7 replies so far
#1 posted 01-01-2019 09:57 PM |
https://www.youtube.com/watch?v=BdwCrM_NMrk :<)))) -- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<)) |
#2 posted 01-01-2019 10:03 PM |
You may have changed speeds while note running the motor (don’t ask how I know). Change the speed back to either 1 or 2 and try again. Can only change while machine is running. |
#3 posted 01-02-2019 01:27 AM |
I have had similar issues with my Delta 22-580. Usually cleaning/waxing the bed and/or cleaning the rollers fixes the issue for me. |
#4 posted 01-02-2019 01:37 AM |
Mineral spirits on the rollers. When mine get dirty the machine stops feeding well. |
#5 posted 01-02-2019 01:48 AM |
Wax the infeed and outfeed trays as well as the deck under the cutterhead. Repeat every time the feed rate slows. -- The hump with the stump and the pump! |
#6 posted 01-03-2019 03:13 AM |
Thank you all that gave suggestions on why my planer wasn’t feeding. The major culprit was the cold temperature and after warming up the planer and waxing the infeed, outfield, and deck under the rollers and cutterhead. I really appreciate all the knowledge here on lumberjacks.com. -- Chris, Central Texas |
#7 posted 01-04-2019 02:16 AM |
I’m glad you got your planer working. When the same thing happened to my Dewalt 735 planer it turned out to be a broken sprocket. It was an easy fix using the exploded view. The part was $11. |
Forum | Topics |
Woodworking Skill Share
13202 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1895 |
Finishing
6348 |
7910 |
32776 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7280 |
1633 |
Focus on the Workspace
2635 |
1272 |
Woodworking Trade & Swap
5419 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9660 |
